Author Topic: 2.5 td vacuum pipe snapped???  (Read 2373 times)
smokingomega
  • Leeds
« on: 21 January 2013, 19:33:06 »
Hi all.
I was changing my heater plugs an accidentally snapped a small vac pipe on the pipe above cylinder 3. It was on to a light blue manifold. The pipe seems not go into the car on the n/s.
Does anyone know what the pipe is for?
Could I just block the broken blue manifold off?
Cheers
symes
  • oxford
    • R reg 940 volvo
Re: 2.5 td vacuum pipe snapped???
« Reply #1 on: 21 January 2013, 19:39:33 »
rejoin with bit of pipe over it :y
smokingomega
  • Leeds
« Reply #2 on: 21 January 2013, 19:46:33 »
Not that simple mate. The blue valve has snapped flush. I have a pipe making kit at work if I could get a new blue manifold from somewhere
« Reply #3 on: 21 January 2013, 20:03:56 »
One vac goes to EGR, via a solenoid, other to heating system. Main vac goes to servo.
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 21 January 2013, 21:19:54 »
I can't picture it, but it seems you need a Tee-piece/Y-piece, of the correct size. I am sure you can jury-rig something until a breaker on here sends you the right fitting. What size does it need to be?
smokingomega
  • Leeds
« Reply #5 on: 22 January 2013, 05:50:59 »
Omegatoy
  • UK
« Reply #6 on: 22 January 2013, 08:05:53 »
blank off the broken bit,araldite or a screw in it,tape it up,etc then put short piece rubber pipe onto the other outlet, then a plastic tee piece available in all good shops for windscreen washers,then connect both pipes to this, it works mine ran like it for 4 years no problem :y
smokingomega
  • Leeds
« Reply #7 on: 22 January 2013, 16:16:49 »
Great. I'll do that. Thanks
Page created in 0.025 seconds with 20 queries.
