SWMBO phoned to say the car won't start
Started by Andy B, 22 January 2013, 15:02:23
Broomies Mate
Quote from: zirk on 23 January 2013, 18:24:44
Quote from: Entwood on 23 January 2013, 17:01:34
Shame you'd not disconnected the battery ... how much damage did she do ???  :(
Was a 1.8, 8V Cav, bent some valves, didn't have much money at the time, managed to hammer the valves straight on my mate lathe, followed with de-choke, HG, Cambelt and Water Pump, good as new.  :y
I thought that was a non interference engine?
zirk
Quote from: Broomies Mate on 23 January 2013, 20:22:04
Exactly what I was told by a 1.8 Manta owner at the time, which was one of the reasons I took the job on with limited funds Ross, decided to check and whip the head off anyway for a de choke and found some slightly bent valves, not badly, but still bent.
Broomies Mate
Quote from: zirk on 23 January 2013, 20:57:44
Every day on OOF is a school day for me!  Always learn something new!  :y
What do you mean by that? sorry, but not heard that phrase that I am aware of, could take a punt but thought I would ask.... :-[ :-[
zirk
#19
Quote from: Vamps on 23 January 2013, 23:53:52
The engine is designed / built in a way that the Head valves will not hit the Pistons through variations of there cycles, ie, if cambelt breaks any valves poking down should be missed by the pistons still rotating, sort of went out the window with twin cam / multi valve design.
Quote from: zirk on 24 January 2013, 00:29:56
Thanks...... :y :y
