Pages: 1 [2] 3  All   Go Down
Author Topic: OIL - Why Am I So Scared ??  (Read 6678 times)
Re: OIL - Why Am I So Scared ??
« Reply #15 on: 23 January 2013, 22:57:17 »
Add 1 quart of ATF and run engine 5 min before draining oil.
LOL!!! is this what we call just over a litre?  ::) ;D ;D ;D
C'mon ..... I know you're only young, but you must surely know imperial unit!  ;) ;) A 'quart' is a quarter of a gallon ie 2 pints bear in mind though that a US pint is smaller than ours because it's only 16 fl oz (fluid ounce) & 'ours' is 20 fl oz  :y :y
lol, so is one quart not just over a litre then?
Nope .. as the poster is in the US of A ...
2 US pints = 1 US quart = .946 litres which is UNDER a litre
if he was in the UK .....
2 Imperial pints = 1 imperial quart = 1.137 litres .. which would be just over a litre
so HIS quart is not the same as YOUR quart
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 23 January 2013, 23:00:13 »
a wealth of knowledge there mate.  :y
RIP Paul Lovejoy
« Reply #17 on: 23 January 2013, 23:08:15 »
Is that not what I said  ::) ........ I managed to avoid those nasty metric units & answer WHY the US quart is smaller than ours  ;) ;)
Webby the Bear
  • Northampton
« Reply #18 on: 23 January 2013, 23:15:11 »
lol yes you did mate, apologies. todays bear prize split  :D
RIP Paul Lovejoy
« Reply #19 on: 23 January 2013, 23:19:44 »
No need ..... I was pulling Nige's leg  ;) ;) ;)
« Reply #20 on: 23 January 2013, 23:25:14 »
Ffs, we're not debating "how much" ATF to put in an engine, are we? Surely!
The answer to which is obviously, none at all. ::)
car5car
  • Florida USA
    • 01 Cadillac Catera
« Reply #21 on: 24 January 2013, 01:02:43 »
I used ATF in engines for about 18 years. I repaired my first engine about 18 years ago. I will change oil in my Catera soon. I will use 20W50 engine and a pint of ATF.
ATF works fine in cars with steering wheel on left side. ;D
Do you use metric system in UK?
km, liters?
« Last Edit: 24 January 2013, 01:06:58 by car5car »
01 CADILLAC CATERA 3.0 engine (Omega)
« Reply #22 on: 24 January 2013, 08:25:18 »
km, liters?
Yes just like pretty much the rest of the planet...  :y :y
« Reply #23 on: 24 January 2013, 09:42:06 »
km, liters?
Nope ... :)
Like the majority of the world we use "litres" ......     :)
Abiton
« Reply #24 on: 24 January 2013, 10:02:26 »
And miles.  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #25 on: 24 January 2013, 10:48:07 »
Except for Beer
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #26 on: 24 January 2013, 11:28:34 »
Except for Beer
then its the slate or tick  ;) ;) ;) ;D
« Reply #27 on: 24 January 2013, 11:29:07 »
km, liters?
 ;D
Have you tried putting sawdust in a diff to cure the noise  ;D
« Reply #28 on: 24 January 2013, 11:35:44 »
km, liters?
The powers that be have been trying to convert us to the metric system for over 30 years, but we're stubborn buggers. The speed limits on the roads are in miles per hour, we generally weigh ourselves in stones (14lbs + 1 stone) we buy beer in pints and although we buy our fuel in litres, we all work our car's fuel consumption out in mpg. If you venture into McDonalds, we buy 1/4lb burgers - Pulp Fiction clip  ;)
If it's cold out, them we'll say it's -5 deg (C) but if it's hot, people will say 'Phew! It's in the 80s'  ::)  ::)
car5car
  • Florida USA
« Reply #29 on: 24 January 2013, 14:37:56 »
Not yet.:)
When I removed valve cover from my Jeep with about 200K miles, rocker arms were yellow, very clean.
Do you want a picture of cylinder heads I work on today? Owner never used ATF to keep engine clean. ;D
If you don't take care of your engine, mechanic will.:)
Pages: 1 [2] 3  All   Go Up
Page created in 0.249 seconds with 16 queries.
