Pages: 1 [2] 3  All   Go Down
Author Topic: TC and ABS  (Read 5405 times)
Re: TC and ABS
« Reply #15 on: 26 January 2013, 09:50:42 »
We have 2 different people with too different faults in this thread.
I think one is an ECU, the other is a sensor due to knacked bracket.
Mart280
  • East Sussex
    • 2001 2.6 CD Auto Saloon
Re: TC and ABS
« Reply #16 on: 26 January 2013, 09:55:09 »
Ok TB which fault is mine :)   (praying for a bracket)
I must be the bracket after having yet another thread read thru :D  It helps to read things in the clear light of day when I havent had a drink :)
« Last Edit: 26 January 2013, 10:09:19 by Mart280 »
Mart280
  • East Sussex
Re: TC and ABS
« Reply #17 on: 06 February 2013, 18:38:39 »
An hour after getting my heating working I went out and noticed both TC and ABS and car with a spanner thru it lights were on and speedo wasnt working, so looks like my ECU was on the way out, the car starts and drives ok and everything else works ok, what are my options chaps considering I am broke.
Re: TC and ABS
« Reply #18 on: 06 February 2013, 18:46:05 »
A suitable second hand ABS ECU/pump,usually around £40 from someone breaking a car on here,or elsewhere. The downside of that is there is no way of knowing how long it will last.
Recondition your one by a specialist company - I believe around £150.
New from Vauxhall - take out a second mortage.
P.S. Its always worth getting a suitable code reader plugged into the car to check the problem isnt a duff wheel sensor before you go any further.Its more likely to be the ABS ECU,but worth checking.
« Last Edit: 06 February 2013, 18:47:43 by Albitz »
Mart280
  • East Sussex
Re: TC and ABS
« Reply #19 on: 06 February 2013, 18:47:40 »
Absolutley no chance it's the sensor ?
Re: TC and ABS
« Reply #20 on: 06 February 2013, 18:48:17 »
Just modified my post above as you were posting yours.  ;D
Mart280
  • East Sussex
Re: TC and ABS
« Reply #21 on: 06 February 2013, 18:56:46 »
Mart280
  • East Sussex
Re: TC and ABS
« Reply #22 on: 13 February 2013, 12:14:40 »
 I haven't had the ABS and TC lights come on together for about a week, today I plugged an OBDII code reader that connects to a laptop into my mig and I saved this out to file
"My Naff Code Reader" 100219a - PC based diagnostic tool
hkj
"My Naff Code Reader" - KW2000 Communication Window> 2001|Omega-B|Engine|Y 26 SE
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0VBM6911051778
vehicleManufacturerECUHardwareNumber 09173199 AA
systemSupplierECUHardwareNumber: BOS  01200261206490
systemSupplierECUSoftwareNumber: 1037360515
systemSupplierECUSoftwareVersionNumber: 0D41
exhaustRegulationOrTypeApprovalNumber: B01003
systemNameOrEngineType:  Y26SE
RepairShopCodeOrTesterSerialNumber:  Not programmed
ProgrammingDate:  20001027
Identifier: 2020
CalibrationDate: 21130401
CalibrationEquipmentSoftwareNumber: 0602
ECUInstallationDate: V-Car 0006
VehicleManufacturerSpecific: 0261206490
Total number of fault codes: 3
U2108 - CAN-Bus no Communication with ABS/TC
 (04) - Not present
P0500 - Vehicle Speed Sensor Malfunction
 (04) - Not present
 (0C) - Not present
I cleared the codes and ran the test again and it came up with no fault codes, is it still looking like a dodgy ABS ECU ?
  • Auckland
    • Mazda MPV
Re: TC and ABS
« Reply #23 on: 13 February 2013, 12:21:35 »
The ABS/TC ECU becomes faulty because Bosch used a series of tiny aluminium wires to connect the circuit board to the electrical connector.
The joints between the circuit board and the aluminium wires tend to fracture and cause an intermittent contact. Once the joints have failed they won't heal themselves.
Mart280
  • East Sussex
Re: TC and ABS
« Reply #24 on: 13 February 2013, 12:24:40 »
Is it definitley the ABS/ECU Andy and not the wheel sensor ?
Re: TC and ABS
« Reply #25 on: 13 February 2013, 12:57:59 »
Iirc you should be able to go into one of the sections (chassis/brakes ?) and see if there is an ABS fault code.Havent done it for a while though,so may be wrong. :-\
Mart280
  • East Sussex
Re: TC and ABS
« Reply #26 on: 13 February 2013, 13:07:44 »
Ok Albitz thanks, I did have a quick look in some of the other sections but just skimmed through 1 or 2 cant remember which, I will have a thorough look through them all when I hook it up next but might be tomorrow, I will report back with any other findings.
Mart280
  • East Sussex
Re: TC and ABS
« Reply #27 on: 15 February 2013, 11:46:56 »
Bloody cars  ::) I go out this morning and the TC and ABS lights are on solid and no speedo and car with a spanner(is that EML?) I  get home dig out lappy connect up to Omega turn on and no TC ABS lights, I found the ABS and TC tests under the chassis section but it didnt throw up any faults, I found some tests where I think you can test each wheel speed, is it worth getting a mate to hold lappy and go for a drive and test these or not, or do I just need to test it when I have the ABS and TC lights lit up.
Thinking about it I may have made a schoolboy error by clearing the stored fault codes from when the lights where on earlier before I went into the Chassis section, when ABS TC come on next time I will not clear them before going into chassis section and having a look in there.
« Last Edit: 15 February 2013, 11:50:09 by Mart280 »
footloose
  • swindon wiltshire
Re: TC and ABS
« Reply #28 on: 15 February 2013, 14:24:57 »
I have just taken the front n/s wheel off to inspect the abs sensor undid the screw waggled the sensor and the whole damn thing fell apart. I have disconnected it taped up the plug and now i'll take off the disc and knock the what is left of the sensor through. Has anyone out there got a front n/s abs sensor. I havn't got enough posts to post on the spare bit for sale so if anyone can help i would be gratefull.
Mart280
  • East Sussex
Re: TC and ABS
« Reply #29 on: 15 February 2013, 14:30:00 »
Thats interesting Footloose, it was the front nearside I replaced a tie rod on just before this started, perhaps I need to take a look.
Pages: 1 [2] 3  All   Go Up
