Author Topic: Ignition Wiring HELP!!!  (Read 9143 times)
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« on: 24 January 2013, 14:42:20 »
Hi guys,
Im trying to find out which wire does what can an OOF electrician help me please
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Sam Burton
    • Many
Re: Ignition Wiring HELP!!!
« Reply #1 on: 24 January 2013, 15:10:38 »
Hopefully this makes it easier
i know the large RED WIRE is the permenant live
whats the others?????????
Sam Burton
    • Many
« Reply #2 on: 24 January 2013, 15:51:16 »
Anyone car in bits here!!
Sam Burton
    • Many
« Reply #3 on: 24 January 2013, 16:18:01 »
Right well im F#cking confused what ever i do i cant seem to figure this out is it me just being retarded?????? can someone make sence of it and turn it back to english for me as ive got an IQ of 8 out of 100  ;D :D
                                                              Black    Red    Blue   Blue
This is what it says on instructions ......
The Black wire should be earthed to the Metal Bodywork (Fine i understand this)
The Blue wire should be connected to Terminal 15(IGNITION) behind the Ignition Switch, with another one connecting Terminal 50 behind the Ignition Switch as well(The Power Path from IGNITION to the Starter Motor)
The Red wire should be connected to Terminal 15 (The power path that passes through ignition)
« Reply #4 on: 24 January 2013, 16:36:12 »
PM sent..
BUT bear in mind that the feed to the ignition switch is fused at 80A so it is not the best place to connect accessories as a short could cause a fire. You would be better off picking up supplies further down the chain where they are more appropriately fused. :y
If you can let us know what you are fitting it would be a great help.
Sam Burton
    • Many
« Reply #5 on: 24 January 2013, 16:40:45 »
Im Fitting a Push Button Kit as it makes sence since i have to turn ignition on to wait for Glow Plugs and then when the Light goes out i can push the button  :y
« Reply #6 on: 24 January 2013, 16:54:58 »
Colour codes for those pins:
15 Black 6mm
50 Black with Red tracer 4mm
But those instructions are very confusing. :-\
« Reply #7 on: 24 January 2013, 16:57:12 »
OK, in that case you are probably being asked to break the 15 wire from the switch and insert this device in series maybe?
I don't like the sound of it, to be honest. :-\
Sam Burton
    • Many
« Reply #8 on: 24 January 2013, 17:02:00 »
15 Black 6mm
Tell me about it!
Sam Burton
    • Many
« Reply #9 on: 24 January 2013, 17:11:22 »
This is the instructions that came with, see if one of you guys can make sence of it
It says Green Wire but its actually Blue, This is the box itself
« Last Edit: 24 January 2013, 17:16:17 by Sam Burton »
« Reply #10 on: 24 January 2013, 19:19:31 »
Hmm. None of those wires look sufficiently rated to take the current that will be asked of them.  :-\
I think I'd be inclined to return it, TBH. Doesn't look like it's up to the job and the instructions don't make clear how to fit it properly.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 24 January 2013, 19:21:47 »
Agreed - those wires look a little on the thin side to me also.
Radio & Decoding Technician
www.dndservices.co.uk
Abiton
« Reply #12 on: 24 January 2013, 19:42:44 »
I predict a riot fire.  :o
Sam Burton
    • Many
« Reply #13 on: 24 January 2013, 21:15:16 »
All sorted finally managed to sort wiring out now starts as should and lights as it should Post some pictures in the light :)
« Reply #14 on: 25 January 2013, 11:46:04 »
All sorted finally managed to sort wiring out now starts as should and lights as it should Post some pictures in the when alight :)
Changed that for you ::)
