Author Topic: rocker covers  (Read 4338 times)
scottambrose
Re: rocker covers
« Reply #15 on: 01 February 2013, 13:25:04 »
well ive degreased it all and washed it all off. driven it 10miles. no smoke and doesnt smell too bad. but there seems to be a very thin smear of oil on the edge of the cover along the lip above where it joins the head. as if its coming down from above.
Re: rocker covers
« Reply #16 on: 01 February 2013, 18:34:19 »
Cover cracked ?
Re: rocker covers
« Reply #17 on: 01 February 2013, 23:27:54 »
Is it near where the filler neck plugs in? Could unplug it and plug the cap in instead to eliminate, if so?
scottambrose
Re: rocker covers
« Reply #18 on: 02 February 2013, 06:23:23 »
Il try that see if it works
symes
  • oxford
    • R reg 940 volvo
Re: rocker covers
« Reply #19 on: 02 February 2013, 10:15:37 »
Cover cracked ?
AS EMD say's  -Mine had crack in it by filler neck :o ???  Dont know how-But crikey the oil was unbelievable _sounds like you got similar problem mate :y
scottambrose
Re: rocker covers
« Reply #20 on: 02 February 2013, 15:55:31 »
Ive now got oil flowing out the back in the passenger side onto the cat and smoking like crazy. >:( im gunna cry I cant see its coming out the half moons. It wasnt doing it before
Re: rocker covers
« Reply #21 on: 02 February 2013, 16:02:02 »
Sounds like it may be now mate  :(
  • Auckland
    • Mazda MPV
Re: rocker covers
« Reply #22 on: 02 February 2013, 18:25:15 »
If the half moons are seated correctly I would pull the coil pack to check if it is leaking into the plug-wells.
scottambrose
Re: rocker covers
« Reply #23 on: 04 February 2013, 09:50:36 »
took it apart this morning. only took 20minutes ;D for the 3rd time. ordered some new gaskets for tomorow and given the ones ive taken off back to vx. really cant see why its done this the other side is fine
scottambrose
Re: rocker covers
« Reply #24 on: 05 February 2013, 08:11:06 »
finally i have no leak.  :) and de greased and jet washed the cats, and fingers crossed its ok now.
Page created in 0.021 seconds with 16 queries.
