Curious SMS issue
Started by Shimmy, 29 January 2013, 15:34:01
Got the same problem. 21 messages, all from 02, and inbox can't cope.
Currently scouring staff at work for a suitable mobile not locked to any other network.
It's not looking good. ;D
I have a cupboard full of mobiles (and my own is on O2) if you get stuck. ;D
Quote from: chrisgixer on 08 February 2013, 11:04:26
Doesn't need to be unlocked. You just want to delete messages.
Of course, finding someone with a phone with a full sized SIM is more of a challenge...
Quote from: TheBoy on 08 February 2013, 13:18:46
Oh it does. It wouldn't even start the pho... Oh hang on, I saw the sim failed message and didn't look any further on a tesco handset. Arse. I remember now, the menus can still be accessed. :y
Although on another O2 handset we couldn't find the relevant texts on the sim. Only the owners texts. :(
It's all so long ago... ;D
Tesco is an O2 MVNO (JV actually) so that handset should work
Modern handsets often store the texts on the phone. Some you can switch between phone and SIM.
I have a SIM read/writer that might do the job, and takes credit card sized SIMs. Now, where's that PC that has a proper serial port, and windows 2K? ::)
Hmmm, you've reminded my, I have a load of lappys with card readers, for certificate based logons. I wonder, with right software, if they could read phone sims  :-\
Used to have a 5110 kicking around here, but can I find the poxy thing. ::)
She's probably traded it in. :(
Quote from: chrisgixer on 10 February 2013, 13:19:42
That doesn't take a full sized SIM either - it takes same size as my superior gayphone ;)
Stallion
Quote from: TheBoy on 09 February 2013, 12:43:13
+1  :y :y
Quote from: TheBoy on 10 February 2013, 18:33:00
No no, it takes the normal size sim. Just brake the sim out of the credit card holder, then tape it back in when done.
Quote from: Stallion on 15 February 2013, 08:23:59
+1  :y :y
That particular hand set doesn't work if the sim doesn't register with the network. It merely allows demo mode.
Eventually found a Nokia hand set that allowed access to the sim memory, as opposed to the phone memory to was using.
O2 texts turned off.  >:(
