Author Topic: Starter Motors  (Read 5387 times)
Re: Starter Motors
« Reply #15 on: 30 January 2013, 22:12:58 »
Take it off and clean off Bendix(thats the bit on end with a small gear) with wd40 then refit mate :y
Ooh  ??? never heard of that , cheers symes ill look it up first  :y
Because, strictly speaking, the Omega has a 'pre-engaged' starter & not a 'bendix' type. The solenoid on the side of the Omega starter engages the pinion with the teeth on the flywheel & then it spins. A bendix starter will spin the starter straight away, the pinion flies forwards on the helix/bendix and then engages with the flywheel's teeth. The advantages of the later pre-engaged is that there is less wear on either pinion or flywheel because they engage while not spinning unlike the bendix.
Not for an Omega mate - for a pug ;)
Re: Starter Motors
« Reply #16 on: 30 January 2013, 22:29:35 »
Although for the pug i understand the working of it now  ;) It does feel like the pinion is moving but not enough to engage so hopefully a bit of cleaning will free it up again
Sounds just like when my triumph herald wouldnt start  ;D
Re: Starter Motors
« Reply #17 on: 30 January 2013, 22:54:15 »
Probably same cause  :) ;)
Re: Starter Motors
« Reply #18 on: 31 January 2013, 16:00:47 »
What are the symptoms
The Pug will be a pre-engaged starter and you should feel resistance towards the end of the throw as the start contacts in the solenoid are sprung and there is a spring which acts to disengage the starter.
Re: Starter Motors
« Reply #19 on: 31 January 2013, 21:15:03 »
Turn key then on occasions it will just give a click and wont turn motor , then other times it will start fine  :-\
symes
  • oxford
    • R reg 940 volvo
Re: Starter Motors
« Reply #20 on: 31 January 2013, 21:20:30 »
as said earlier take it off give it a clean and refit mate  :y
Re: Starter Motors
« Reply #21 on: 31 January 2013, 21:24:33 »
Re: Starter Motors
« Reply #22 on: 01 February 2013, 20:28:01 »
Its more likely to be the solenoid
Re: Starter Motors
« Reply #23 on: 01 February 2013, 20:39:09 »
Is that a replaceable part ?  :-\
