Author Topic: Diesel Magic Trick done, now how do I start the thing?  (Read 6537 times)
Agemo
  • Cleethorpes
  • Insignia
Re: Diesel Magic Trick done, now how do I start the thing?
« Reply #15 on: 31 January 2013, 21:51:58 »
Thanks Omegatoy, I appreciate the help. With no coverage in the Haynes, EPC not working, plus the fact that I never had a problem last time, I was baffled!
Omegatoy
  • UK
« Reply #16 on: 01 February 2013, 18:18:05 »
lol I would bet money you never make the same mistake again! :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #17 on: 01 February 2013, 22:06:24 »
Oh I will remember all right, I am still baffled about the two different filters:0
and
They have different numbers, but according to the EPC they both fit.  ::)
conalnugent
  • n. ireland
« Reply #18 on: 02 February 2013, 06:53:44 »
sorry to be a green horn but what exactly is the magic diesel trick?
Agemo
  • Cleethorpes
  • Insignia
« Reply #19 on: 02 February 2013, 08:54:18 »
When replacing your fuel filter, instead of filling it with Diesel, use a product called "Diesel Magic" (Redex or similar will give the same results). The theory is that it will go through the pump, lines, and finally injectors, at a strong concentration. This should clean out the system far better than using a small amount diluted in the tank. I tend to do this every time, and am convinced it works.
conalnugent
  • n. ireland
« Reply #20 on: 02 February 2013, 23:08:32 »
Nice. I'm liking the sound of this.  Quick question, will a motor sitting about a while can this leave injectors clogged? Thanks sorry for the hijack
Agemo
  • Cleethorpes
  • Insignia
« Reply #21 on: 03 February 2013, 08:53:42 »
Injectors won't clog because the car has been standing a while, however, there is dirt in all fuel. This dirt is in suspension, and if a car is stood, it will settle to the bottom of the tank. When the engine is started & the car moved, this layer of sediment is pulled towards the lift pump. Your first place to check would be the filter in the tank, there is a brilliant "How-to" in the Maintenance guide.
