Author Topic: head light  (Read 2658 times)
bored bigyin54
  • south wales
    • black beast
head light
« on: 30 January 2013, 23:03:03 »
just a quick one for you . how do i get condensation out of my front light . only noticed it today . thank you :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: head light
« Reply #1 on: 30 January 2013, 23:13:46 »
Make a hole in the glass and use a syringe!
Re: head light
« Reply #2 on: 30 January 2013, 23:23:30 »
Fit an extractor fan?
Seth
Re: head light
« Reply #3 on: 30 January 2013, 23:35:33 »
Viscous would be better IMO :y
Re: head light
« Reply #4 on: 30 January 2013, 23:39:23 »
Humidistat? :-\
Seth
Re: head light
« Reply #5 on: 30 January 2013, 23:53:08 »
Humidistat? :-\
Might be a problem routing the wiring around the engine bay ... reckon that it'd work, though ;)
Re: head light
« Reply #6 on: 31 January 2013, 00:05:10 »
I wouldn't worry too much Wilf, they do that from time to time. Has it been through a car wash? :)
Re: head light
« Reply #7 on: 31 January 2013, 07:12:49 »
Check grommets are sealed at the back of light unit , run car with lights on an will dry it out  :)
Pattern bulb might take longer to dry it  ;D :y
bored bigyin54
  • south wales
    • black beast
Re: head light
« Reply #8 on: 31 January 2013, 12:58:00 »
thought i wouldn'd get no sense out of some of you  :y :y
mantahatch
Re: head light
« Reply #9 on: 31 January 2013, 14:07:57 »
I suffered with this on one car, did wonder after the event whether I could have got a small packet of dessicant in there, you know that stuff that comes with goods sometimes to keep the moisture out.
Just a thought.
Re: head light
« Reply #10 on: 31 January 2013, 14:14:29 »
I would take the unit off the car and point a hairdryer in there for a while,then leave it stood in a position (in a warm place like an airing cupbourd)where any moisture can drain out where the bulbs attach.
Re: head light
« Reply #11 on: 31 January 2013, 14:20:49 »
It removing the unit, make sure the rubber vent is clear on the base. It usually is, but one to check.
I suspected the seal had failed between the glass and black backing, on one of my other cars. Maybe careful application of a hosepipe will reveal if water is getting in.
But usually it evaporates off with use ime. ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: head light
« Reply #12 on: 01 February 2013, 23:09:24 »
this use to happen regular on my carlton,
 was told to remove the rubber boots dry out with a hair drier and leave the boots off for a week or so then put back on, worked a treat.
Hoof'land storeman.
