Author Topic: Ex Police Parts / Goodies for sale.  (Read 8025 times)
gstylebaby
  • stockport
Re: Ex Police Parts / Goodies for sale.
« Reply #15 on: 03 February 2013, 17:22:23 »
If the sale of the chip and throttle bodies falls though and they will fit my 3.0l estate then give me next shout  please. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #16 on: 03 February 2013, 18:30:25 »
Will do, I'll add you to the list.  ;)
zirk
  • Epping Forest
« Reply #17 on: 03 February 2013, 18:45:26 »
Just to clarify, as been asked a few times now, in case anybody wants to withdraw.
The Throttle Bodies are slightly wider in Diameter than normal and have been polished and ported to the Penlum, the Butterflies have been Razored and the Spindle has also been flowed. These are from a 3.0 and will only fit the 2.5/3.0's. not the 2.6 or 3.2's.
The Chip is also 3.0 and will fit 3.0 Auto or Manual, again not 2.6 or 3.2, wouldn't have thought it would fit 2.5 but could be wrong.
The Cams are all G type, ie inlet and exhaust are the same, will fit 2.5 and 3.0. no idea if they are suitable for the 2.6/3.2 guessing not.
Hope that helps.  ;)
Just with a had a box load of the Throttle Bodies, could have sold out by now  :y
zirk
  • Epping Forest
« Reply #18 on: 03 February 2013, 21:56:28 »
A bit more clarification from questions.
The Chip is Eprom based and can easly be replaced. All the 3.0 ECU's I have come across have the Chip Holders fitted. I dont know what the Bhp increase is but if was th guess Iwould say between 5 and 15. The chip should work as a stand alone and does not need the Throttle Bodies or Cams but with this in mind might work better as a complete kit.
The LSD as far as I can calculate is 3.9 ratio, the same as normal Auro's ratio, the increased accleration bit came from the fact that if fitted to a Manual (normaly 3.7) it will give improved accleration over a normal.
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #19 on: 03 February 2013, 22:01:25 »
PM sent re LSD
PM with your requests.
zirk
  • Epping Forest
« Reply #20 on: 03 February 2013, 22:22:32 »
zirk
  • Epping Forest
« Reply #21 on: 04 February 2013, 12:00:02 »
- Enlarged Throttle Bodies £100 ono. Provisional Sold.
- 3.0 Remap Chip, £90. Provisional Sold.
- Cams,(G) inlet x 2 and (G) exhaust x 2. £100 ono. Provisional Sold.
- Fully working LSD £230 ono Provisional Sold.
- AR35 Autobox, does what it says on the tin, plus any associated parts you may need, please note buyer removes from Car, as dont have time or effort to remove myself, otherwise will get weighed in with the Car, Hence price £70 or offers.
- Heavy Duty Alternator, £30 ono. Provisional Sold.
- 3.0 Cats x 2, £100 ono.
- Calibrated Police Speedo (155mph), £15 ono. On Hold.
Chris  ;)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #22 on: 06 February 2013, 01:21:54 »
It was in a picture that Josh sent of it,if it's the same car then you could be right as the headlight washers have been fitted incorrectly,although the first thing I did when I got it was put in for a full respray as typical of red VX paint it was past its best only three years in service ::)
Close, the one Josh had was also ex DPG but a 3.2, reason I know is I have that Car tucked away at the moment,  ;) (dont ask), This is another one but 3.0, just a shame the engine Mods wont fit the 3.2 DBW!
I was getting my hopes up then, but looks like i've missed the boat anyhoo... Might have those wheels off you Chris...
zirk
  • Epping Forest
« Reply #23 on: 08 February 2013, 14:24:51 »
I did have a quick look to see if I adapt the Throttle Bodies for my 3.2, but its a bit of a non starter.  :-\
