Author Topic: misfire  (Read 1908 times)
greenman
  • greenock
misfire
« on: 04 February 2013, 16:46:13 »
Water in plugwell no.4 caused misfire.
dried it out,misfire cleared.
water was clear so not coolant(red)
2.2 facelift.Seem to remember something about rainwater getting
in somehow.
any thoughts?
Re: misfire
« Reply #1 on: 04 February 2013, 16:51:34 »
Scuttle join likely culprit
greenman
  • greenock
Re: misfire
« Reply #2 on: 05 February 2013, 09:59:25 »
Any advice on how to cure this?
Re: misfire
« Reply #3 on: 05 February 2013, 14:16:21 »
As Rob says above, the scuttle join point or the base of the wiper arms is letting water through.
This drips onto cam cover and into pot4, feel under the foam to see where its wet.
But a dab of clear sealant around wiper arms should fix it, but also check join point  :y
Mart280
  • East Sussex
    • 2001 2.6 CD Auto Saloon
Re: misfire
« Reply #4 on: 05 February 2013, 20:41:00 »
My scuttle was leaking like a waterfall, as Tunnie said sillicone the joint, I also sealed the joint from  underneath with a couple of strips of Denso tape and it leaks no more :)
greenman
  • greenock
Re: misfire
« Reply #5 on: 06 February 2013, 11:42:33 »
Dried out,sealed as said.
Here,s hoping!
