Author Topic: Paper Clip Test Not Work  (Read 2791 times)
wesagog
« on: 06 February 2013, 19:32:09 »
Hi,
I'm trying to do the paper clip test for my Omega B, 1996, 2.0L but no any response noticed...
any help pls.
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: Paper Clip Test Not Work
« Reply #1 on: 06 February 2013, 19:37:58 »
i assume you are doing the paper clip test without the engine running :-\,it will only work with the ignition on and no engine running  HTH  :y
this link may help    http://www.omegaowners.com/forum/index.php?topic=90581.0
« Last Edit: 06 February 2013, 19:41:24 by noel »
wesagog
« Reply #2 on: 06 February 2013, 19:48:25 »
No, I did it according to the instructions, and I used to do it before that many times... but now there is no response...
« Reply #3 on: 06 February 2013, 20:14:30 »
Does yours normally have 2 digit fault codes, or 4 digit fault codes?
If the latter, it just means no (recent) stored faults :)
wesagog
« Reply #4 on: 06 February 2013, 20:32:08 »
It's 2 digit codes and I did it many times before, now it's not work and it's even didn't give Start Test Code (12)
« Reply #5 on: 06 February 2013, 20:33:39 »
metal paperclip ?? not a plastic covered one ???
Abiton
« Reply #6 on: 06 February 2013, 20:34:10 »
Bulb blown. More than likely.
wesagog
« Reply #7 on: 07 February 2013, 14:40:12 »
Dears,
Sure, I use metal paper clip and no any blown bulb...
I really need your advice... please
« Reply #8 on: 07 February 2013, 18:41:53 »
Where are you?
wesagog
« Reply #9 on: 07 February 2013, 18:57:48 »
Baghdad, Iraq
OmegaAnglesey
« Reply #10 on: 07 February 2013, 19:01:02 »
Baghdad, Iraq
I don't think anyone on OOF is close enough  :-\
Abiton
« Reply #11 on: 07 February 2013, 19:05:52 »
Dears,
Are you saying that the bulb which illuminates the Engine Management Light has been tested/checked, and it definitely works, since this 'paperclip test not working' has been observed?
« Reply #12 on: 07 February 2013, 19:22:32 »
Baghdad, Iraq
Ah, yes, a bit of a trek from England ;D
Page created in 0.022 seconds with 20 queries.
