Author Topic: Block to sump sealant  (Read 1105 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 07 February 2013, 22:15:54 »
Does anyone know what the sealant used that sandwiches the block to the sump is (on a V6 at least)? I don't mean the sump tray (which in the pic below shows grey sealant) but I mean the actual top assembly that joins to the bottom of the block? I *think* it's the black gasket type sealant used elsewhere but wondered if anyone knew for sure?
I've highlighted the bit I mean in the following pic:
PM with your requests.
Re: Block to sump sealant
« Reply #1 on: 07 February 2013, 22:24:53 »
If you mean the main casting Dan (upper sump), use the grey
« Reply #2 on: 07 February 2013, 22:27:48 »
I would have thought grey would be best :y
humbucker
  • Cambridgeshire
« Reply #3 on: 07 February 2013, 22:29:51 »
Thanks chaps, much appreciated.  :y
