Author Topic: NCDC Replacement Laser Lens  (Read 8352 times)
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: NCDC Replacement Laser Lens
« Reply #15 on: 11 February 2013, 18:05:51 »
Here is a How To, its in Dutch but probably you can read the photo's. ;D
Replacing the laser NCDC 2011/13/15
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #16 on: 11 February 2013, 18:33:16 »
Thanks..
Chrome translates it but takes all the comments from the photos and puts it all in one paragraph..
« Reply #17 on: 13 February 2013, 15:59:43 »
Easy enough to do if a little fiddly.
No setup required as the PIN diode is ready calibrated.
Weds
  • Chatham, Kent
  • My other hobby
« Reply #18 on: 13 February 2013, 16:51:23 »
Are the lasers the same for the top and bottom CD slots on the NCDC2013 ?
« Reply #19 on: 13 February 2013, 16:58:29 »
Nope, bottom one no longer available but can be sourced secondhand.
« Reply #20 on: 14 February 2013, 12:53:22 »
IMO, its interesting that the bottom cd changer laser rarely plays up.
Ime at least, its always the top nav slot. I suspect the nav is constantly reading the nav disc, if inserted, and it just wears out.
Maybe removing the nav disc if not in use might help?
« Reply #21 on: 14 February 2013, 12:54:24 »
It is permanently reading the disc.  :y
« Reply #22 on: 14 February 2013, 13:13:13 »
I'd better take my disc out then ???
« Reply #23 on: 14 February 2013, 13:16:12 »
Yes, I've sine lost mine though.  :-[  ;D
« Reply #24 on: 14 February 2013, 13:55:39 »
Thats because you don't play many CDRs in your CDC, as you use your uphill gardener gaypod thing.
I get through more CDCs than I do top slot mechs
« Reply #25 on: 14 February 2013, 14:30:24 »
stop using CDR's then, silly!
Gaypod player has a draw back, its only compatable with an outdated iPod, 3rd gen iirc. Therefor the battery will be fe@ked. The lap top wont charge it, so can't update the play lists, so it doesn't get the use as I'm bored with the contents.
Top slot has Paloma Faith. :y
« Reply #26 on: 14 February 2013, 15:02:39 »
I don't need to as I have a stack of CDC3s here ;D ;D ;D
« Reply #27 on: 14 February 2013, 15:35:16 »
::) ;D well leave some for the rest if us ;D
