Unbelievable!!
Started by jonny2112, 09 February 2013, 15:09:51
jonny2112
Cheers Rob.
I thought that was the case, but worried that I had got it wrong.
Still can't understand why one was loose though  :-\
Quote from: jonny2112 on 10 February 2013, 18:48:53
Cheers Rob.
Threadlock not used?
Coolant pump pulley bolts:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Angle-tighten a further 30°
Stage 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Angle-tighten a further 30°
HTH :y
Personally never torqued mine - just done up sensibly tight with a socket and short handled ratchett.  Never had any come loose or even fall out.
jonny2112
No, no thread lock, on any of them. And I've a notion I didn't actually torque them ......
Quote from: RobG on 10 February 2013, 18:46:19
Reply #4
http://www.omegaowners.com/forum/index.php?topic=110080.0  ::)
Hang on, I just twigged. Same issue, same op, link from last year.
What's up Jonny?  ???
jonny2112
I really don't know  :-X
It's a bit odd to say the least.
Over enthusiastic use of spanners maybe ::)
jonny2112
Right, plan A isn't working. The water pump is going to have to come off.
Can it be reused once the 'seal' is broken, or better to replace?
It's only recently had full coolant change too! Aargh  >:(
No problem with re-using the pump. The sealing O ring might benefit from replacement.
If you can catch the coolant there's no reason not to re-use that either.
jonny2112
jonny2112
Well had to fit new pump, and refilled with fresh coolant. Sorted  :y
Just need to keep an eye on things, and ensure the pulley bolts form part of my weekly ish checks  :-X
On a different note - was cleaning around in the bay, partly to dry everything off to check for leaks, and found some writing on the alternator. It was marked '3.2 V6' in white marker or something, so has obviously been replaced at some point!
