Author Topic: 2.2 dti rear brake discs  (Read 2659 times)
zarehs
  • ILFORD, Essex
« on: 09 February 2013, 16:18:32 »
I have some scraping and squealing, general frictiony type noises coming from my passenger rear wheel area at low speeds.  I suspect its the rear brakes.  Just searching on the net, I see rear brake discs that are supposedly compatible with my 2.2 dti, varying in size.  They are available in 12mm and 20mm thickness.  Does anyone know which are the right ones for my car?
Re: 2.2 dti rear brake discs
« Reply #1 on: 09 February 2013, 16:22:37 »
Check the pads, its more likely that's been filed right down  :y
    • 530D M Sport, 330i Coupe
« Reply #2 on: 09 February 2013, 16:36:41 »
Check the handbrake cable isn't seizing in the nylon sleeve as well.
Omegatoy
  • UK
« Reply #3 on: 09 February 2013, 18:31:24 »
Hmm generaly when you get scraping noises its the handbrake shoes inside the disc causing it!
most but not all times its a spring broken and its catching on the inboard drum :y
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 09 February 2013, 20:59:04 »
or rotted out retainer pins/back plates :y
zarehs
  • ILFORD, Essex
« Reply #5 on: 12 February 2013, 18:56:18 »
right, garage says rear brakes are done and handbrake needs a bit of a fix.  Back to my original question around 20mm vs 12mm discs as  both seem compatible, which are the right ones?  I guess the question really is does a 2002 2.2 dti have vented or solid rear brake discs.
Ta
« Last Edit: 12 February 2013, 19:06:10 by zarehs »
« Reply #6 on: 12 February 2013, 19:14:18 »
Solid :y
zarehs
  • ILFORD, Essex
« Reply #7 on: 12 February 2013, 19:26:31 »
cool man - that will save me a bit of money  :y Solids are 12mm width sorted.
thanks elite pete
« Reply #8 on: 12 February 2013, 19:29:16 »
No problem :y
zarehs
  • ILFORD, Essex
« Reply #9 on: 12 February 2013, 19:53:34 »
Just occurred to me, do I need to buy a brake fitting kit along with the discs and pads?
« Reply #10 on: 12 February 2013, 19:55:59 »
Yes, it all generally falls apart when you remove it.
