Author Topic: whats going on !!  (Read 2309 times)
symes
  • oxford
    • R reg 940 volvo
whats going on !!
« on: 09 February 2013, 21:46:38 »
The miggy doing my head in again started it today fine- went out later and it sits there reving up and down on its own so revved it few times then settled down yo steady idle- What is going on  >:(
no fault codes - checked  :y
martin42
Re: whats going on !!
« Reply #1 on: 09 February 2013, 21:49:18 »
Icv might need cleaning  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 09 February 2013, 21:54:50 »
looked fine but do i use 3 in 1 oil to lube it-if so how mush and where do i put it-not being funny-neveer had to do icv
before :y Had all sorts of miggy nightmares to do but not icv
« Reply #3 on: 09 February 2013, 22:35:07 »
There's a little plunger that rotates and opens or closes the ICV. Pretty self explanatory once you have it on the bench. Rinse it out with carb cleaner then a little oil on the plunger so it can rotate freely.
Check for air leaks around the ICV and elsewhere while you're at it. If you get a leak big enough to raise the idle speed above limits, the ECU will cut fuel until the RPM drops and this can cause it to cycle up and down repeatedly.
« Reply #4 on: 09 February 2013, 22:39:12 »
As above - sticky ICV or air (induction) leak ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 09 February 2013, 22:43:26 »
Cheers fellas :y :y Will be playing about tomorrow now- I know why miggys have large hoods bonnets--Keep you dry in the rain ;D ;D ;D ;D No Seriously many thanks :y
symonde
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 10 February 2013, 23:04:55 »
Well did icv today- now idles once warmed up otherwise stalls :o-my mate checked fuses ??? and number 29 blown ??? put new one in and whole dash lit up :o :o took it out-again ??? so parked it up and gave in-my old man given me his ratty astra van (its filthy/rusty but goes) so gonna use that for now as so fed up with the miggy- getting to hate the car-seriously I am-have been surfing egay checking prices as reckon its beyond me now :'( mechanics/engineering-can do Electickery not so good.
« Reply #7 on: 11 February 2013, 00:51:22 »
Believe thats live feed to towbar.  Have you got a towbar fitted mate?  If so you may have a wiring issue with it if fuse 29 keeps blowing.  Leave it out won't affect engine idle/running ;)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #8 on: 11 February 2013, 02:15:13 »
possibly blocked breathers/low engine oil  :-\ . only saying as i had similar issue cleaned the throttle body and the breathers and hasnt happened since?  :y
