Omega replacement ?
Started by Entwood, 10 February 2013, 23:21:43
Some of the "offers" are getting a little outside the parameters ... remember ... 4 door saloon, rear wheel drive (or AWD), minimum weight 2200 Kgs, minimum power ITRO 220 bhp, auto box.
Quote from: OmegaMan2.2 on 12 February 2013, 17:36:55
Quote from: Entwood on 12 February 2013, 17:34:08
http://www.autotrader.co.uk/classified/advert/201302045190734/sort/default/usedcars/body-type/saloon/engine-size-cars/2-6l_to_2-9l/model/insignia/make/vauxhall/onesearchad/used/onesearchad/nearlynew/onesearchad/new/postcode/ll669aa/radius/1500/page/1?logcode=p
MMM Insignia .. always thought they looked "small" ... but on that spec sheet they seem reasonable ... :)
In Estate form perhaps ? Saloon looks a bit gay, I'm told. :-\ ;)
Think I'd rather trust a Phaeton mechanically, than an Insignia in any guise. Tbh.
Rods2
The 3.0l V6 tractor is the same lump as used in the VW Touareg and probably has the same reliability as a business colleagues. All I can do is recount his problems and wish you the best of luck on reliability and running costs.  :o :o :o :o
He has spent in the last few months £1,200 on new DPF and has now got a common worn / leaking injectors problem and has been quoted a mere £3,200 by his local VAG garage to replace them.  :o :o :o :o :o :o
Trying to help him out, the cheapest I could find for geniune Bosch injectors was £295 each, but he has managed to get 6 second hand for £100 each, so still with fitting an £800 repair bill. Suspect it will be HPFP next, but I think he hopes to have got rid of it by then!  ::) ::) ::) ::)
Apparently they use Piezo injectors and not solenoid ones and they are not very reliable. Current thoughts are that any fuel contamination damages the ceramic discs within the injectors. Water contamination is meant to be especially bad as this turns to steam through heat and pressure at the injector ceramic discs and shatters them, the particles damage the injectors, the discs don't seal so they leak and the return pipe contains ceramic particles which through the return pipe, end up going through the HPFP to damage that. So you are looking at a an £1,800 plus bill if you source new injectors and change the injectors yourself and probably also looking at needing a new HPFP at £800.  >:( >:( >:( >:(
£3,800 buys an LPG kit and an awful lot of LPG!  :y :y :y :y
Quote from: chrisgixer on 12 February 2013, 17:48:25
Estate is not a patch on the Omega. Does feel quite small on inside. Think Jag XF Estate would be nice, need to wait a while for prices to lower though
Quote from: Rods2 on 12 February 2013, 19:24:11
As do quite a few of the common-rail diesel engines. They're a real PITA and very fragile but I don't buy the contamination stories. We go out to many vehicles with Piezo injectors and once drained and flushed through they perform faultlessly, although who knows if they fail in another 10-100k ::)
