Author Topic: f.p.r vac pipe??  (Read 1385 times)
omgj
  • exeter
    • 3.0l elite
f.p.r vac pipe??
« on: 11 February 2013, 09:36:16 »
hi think my fuel pressure regulator may have the wrong vac pipe on it!
should it have the vac pipe from the idle valve or one from the brake servo hose??
cheers
Re: f.p.r vac pipe??
« Reply #1 on: 11 February 2013, 09:57:03 »
cheers
From memory, it's the pipe that has the moulded U shape & comes from a stab in on the large pipe from the idle air valve
omgj
  • exeter
    • 3.0l elite
« Reply #2 on: 11 February 2013, 10:24:34 »
sweet thats what i thought! turns out mine has been plumbed in wrong so hopefully that will sort out my lack of power!?  :y
« Reply #3 on: 11 February 2013, 10:44:06 »
I'm sure RobG will have a picture for you later .......  ::)  ;) ;)
« Reply #4 on: 11 February 2013, 15:51:48 »
Yep, the fuelling will be way off if there's vacuum on it as, on the Omega, it's actually referenced to atmospheric pressure just ahead of the throttle body.
Abiton
« Reply #5 on: 11 February 2013, 16:39:23 »
Apart from the 4-pots.  Irrelevant here, I know.
