If I didn't want coolant level on MID anymore could I...
Started by Webby the Bear, 12 February 2013, 12:19:41
Webby the Bear
Quote from: RobG on 12 February 2013, 16:00:22
Just the plug Steve, and yes, bridge both female terminals (at the plug) and tape secure
Cheers Roberto Di Bro-teo  :y :y :y
RIP Paul Lovejoy
Webby the Bear
Quote from: ffcgary1 on 12 February 2013, 16:01:54
just replace the tank man, its a 10 min job. ::)
lol i'm not bothered about swapping it over  ::)
it's making the decision as to whether i want to keep the level sensor or not.  :y
RIP Paul Lovejoy
martin42
keep it,it can be an engine saver,if you suddenly lose coolant you will know about it,instead of having a seized engine which will cost you a fair amount to sort out compared to £35 for a new coolant tank :y
10 mins including buying the tank and lunch ::)
Quote from: martin42 on 12 February 2013, 16:09:18
Indeed. A sudden leak of coolant could leave the temperature sensor without any flow past it, so before you know what's happened, the engine will be wrecked.
biggriffin
Hoof'land storeman.
Broomies Mate
Hmmmm.
Perhaps this is falling on ears who do not wish to hear, but I lift the bonnet on my car at least once a week to top-up washer fluid, run a rag around the bay etc.........  Who would HONESTLY pull over the very instant the MID said 'Check Coolant Level'?
I'd wager nobody who really knows their car would.
We would keep an eye on the temp gauge, have a look-out for steam and drive on until we reached our destination and THEN have a look...... wouldn't we?
Webby the Bear
Quote from: Broomies Mate on 12 February 2013, 20:50:25
Hmmmm.
I personally agree.  :y
RIP Paul Lovejoy
dbdb
is it always the tank causing the low level warning?  On my last mig I kept getting it and recall ruling out the expansion tank sender and assumed there was another sender somewhere and an airlock.  It coincided with the heater being only luke warm.  Both both problems were alleviated simultaneously by a fairly savage descale.
Quote from: dbdb on 13 February 2013, 21:04:05
Yep, sort of... It's the level sensor in the tank ;) I think the result you had was down to the de-scale :y
Hmmmm.
I would for exactly the reason you state. Well, not instantly but ASAP ;) I keep on top of my cars (generally) so would know that the warning coming up was for a reason ;)
In fact, on my saloon I had this happen on the way down the A3 to go to a funeral... Pulled over and sure enough coolant was low due to a failed HBV. Managed to limp it to the funeral and the 160 miles home though, once I'd worked out what CC setting I needed to minimise the leak :y Probably saved the engine at the speed I was going :-X
dbdb
Quote from: Lazydocker on 13 February 2013, 21:11:36
No I had already thoughly descaled the float in the tank, no difference.  First thing I did (and a lot easier than descaling the whole system).  Thats why I didn't think it was the expansion tank sorry float in the tank sorry sensor under the tank activated by float in the tank sorry switch in the sensor activated by float in the tank ;)
