Pages: 1 [2] 3  All   Go Down
Author Topic: My list of jobs for the CDX  (Read 4779 times)
Jay w
  • Plymouth/Poole
  • omega gone
Re: Progress on the CDX
« Reply #15 on: 05 May 2008, 12:48:58 »
cheers guys :y
I really need this up together as quick as possible as i want to have 5-10k on the new engine before we go to France (july 5) and i want the gas kit fitted soon as well
One thing i will say about her, very smooth indeed, i can imagine that there is so much difference between the CDX and Elite models, this leaves me to think that there were a few things that weren't right with the Elite.
Petrol fuel economy is a lot better as well, the 2.5 was giving me 28 on a run, last night this was up around 32!!  :o i was well chuffed
Now got to order 2 sets of infinity 5010CS's for the front and back doors and a set of 6010's for the rear shelf
5010CS - aren't they small speakers?
I have 606CS in the front with the XOvers in the armrests
5010's are 5 1/2 components with separate x-overs i have a set in the Alfa and they sound great, they will need spacing though
Cheers for the comments guys, i have been a bit flat out on it this last week or so, it's going to be doing 30k a tear so everything has to be just right.
LPG kit gets ordered next week so i can make a start on that soon  :y this time i am going to try and do a how to
Varche
  • middle of Andalucia
    • Golf Estate
Re: My list of jobs for the CDX
« Reply #16 on: 05 May 2008, 14:12:22 »
Blimey, what a fast worker.
You don't fancy nipping down to see me in Spain from when you are on holiday. I need my cambelt and gearbox changing.
You (well we) should have it done by lunch despite it being a seven hour drive from where you are staying. You would be back having a sundowner by 7p.m.
varche
Martin_1962
« Reply #17 on: 05 May 2008, 16:26:09 »
cheers guys :y
Fit 6.5s in the front - plenty of room
Martin_1962
« Reply #18 on: 05 May 2008, 16:26:53 »
While the door is off put the XOver in the armrest - chop out some of the thick foam
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #19 on: 07 May 2008, 19:27:04 »
well the LPG kit has been ordered today, another kit from Jeremy.
This time i am going with an 80l tank and the same Stag 300 set up i had last time.
He has been very kind and supplied me with a french adaptor and a spart fuel filter as he was saying the french don't filter their gas to the same quality as we do, as a result i may have to clean the injectors when i get back to the UK and a filter change is recommended as well at the same time.
The system is the same one that JamesV6 and i have used, i believe Marie has the 4 cyl version, its a fully adjustable system that can be mapped using the software supplied that will also help with fault diagnosis
I have no vested interest in this chap as others on here will testify, but he is a mountain of help, i am hoping that the kit should be with me before the weekend, if it is then we start with the tank this weekend and do the front end during the next week.
here is his ebay address, he was telling me he is doing less on there now as word of mouth is selling more kits than ever before
http://search.ebay.co.uk/_W0QQsassZu-fit-lpg
i will be tring to do a 'how to' however as i found last time, my methods and my car will be different from others, i have already hit an issue of mounting the vapuriser as i now have another waterpump in the way, never mind we will overcome
« Last Edit: 07 May 2008, 19:27:28 by jay_w »
zippo
  • manchester
« Reply #20 on: 07 May 2008, 19:39:38 »
is that the same  kit that  Danny had fitted  :question
« Last Edit: 07 May 2008, 19:40:01 by zippo »
Martin_1962
« Reply #21 on: 07 May 2008, 20:36:56 »
I moved my pump Jay - about 1 inch was enough
Martin_1962
« Reply #22 on: 07 May 2008, 20:37:35 »
I think the Jeremy kit is Stag but Dannys is OMVL Dream
« Reply #23 on: 07 May 2008, 21:14:33 »
Been thinking about that pump myself. I will get round to doing mine one day. I believe it only runs when parked up with the heater on so it should be possible to ditch it entirely. It's right where I'd put the vaporiser.
I'm thinking of redirecting the pipes around the back of the engine so it gets flow all the time rather than only on heater and then using the rather nice moulded pipes to feed the vapouriser, possibly with the pump still in circuit or possibly not. :-/
I'd be interested in the dimensions of the tank you've gone for, Jay.
It was indeed one of those systems we fitted to Marie's car and it went like a dream. In fact, due to a little wiring fault by yours truly  :-[ when we first filled the tank it refused to run on petrol so started up, pulled away from the garage and up the road to the nearest layby where we could tinker on gas without any calibration. 8-)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #24 on: 07 May 2008, 21:27:32 »
i have been looking at the area in front of the dirt shield under the wheelarch, it id below where the airbox sits, i believe its where the self levelling pump would have sat on my elite, its out of the way, discreet and i am sure a bracket could be made to support the unit.
I still have to sort out the brackets for the injectors, i may tap into the plenium for that, having the long one and no EGR or ICV units is a bit of a blessing really.
I was hoping that the water hoses to and from the pump could be interrupted and the vapouriser fed from that point, oh well, back to the old way of doing it, it worked last time, it just means that it is really bust round the back of the engine
Kevin as soon as it arrives i will get the dimensions for you  :y
sassanach
  • trowbridge
« Reply #25 on: 07 May 2008, 21:30:28 »
why dont you fit the 100 litre tank? you will lose no more usable space in the boot.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #26 on: 07 May 2008, 21:38:22 »
fair point, i am on a slight budget and that would take me over by quite a bit.
The 70l tank was ok, i was finding that i could do most of my journeys with only have to fill  up for the return trip.
sassanach
  • trowbridge
« Reply #27 on: 07 May 2008, 21:44:06 »
on a run my 100 litre tank would carry me 400 miles +.where i am in the trowbridge area we are well served with lpg pumps but once you leave the area it gets more interesting. :)
« Reply #28 on: 07 May 2008, 21:45:43 »
Spooky. I was just looking at that area on mine about 10 minutes ago. Either for the vapouriser or the ECU.
Yes. Should make things easier. Either that or replace the plenum bolts with slightly longer ones, Pack out the recesses and run a bracket from the plenum bolts down to the side of the plenum.
The water pump is after the HBV at the moment. However, re-jigging the pipes behind the engine would soon fix that. Makes no difference to the pump where it is in the system, and then you can run the vapouriser from the pump pipes, and potentially put the pump in series with it if room is available
Excellent. I'm hoping that I can find a reasonably large tank that will still give some room for lobbing the odd long load (bits of wood, etc) through the hole behind the back seats, so either a cylinder that uses the whole width but is reasonably slim, or one that uses the whole height but not the whole width would be good. Range isn't a huge issue. As long as it does 200-250 miles I'd be happy. Need to go and measure up the boot, I guess.
« Reply #29 on: 07 May 2008, 21:51:42 »
Re the 100 ltr tank ...  :)
When mine was measured by the place that is doing the work (goes in on Saturday) they said I would have to have an 85 ltr tank (68 ltrs useable gas) as that is the max that fits between the suspension "bulges".
Could this be due to their suppliers being different to others, or what ?? 15 ltrs is not a lot I know .. just wondering about the discrepancy .. :)
Pages: 1 [2] 3  All   Go Up
