killed miggy !!!
Started by symes, 16 February 2013, 21:10:48
Quote from: symes on 17 February 2013, 18:33:23
Quote from: Lizzie Zoom on 17 February 2013, 12:42:56
Quote from: kevinp58 on 17 February 2013, 10:39:26
Quote from: dbug on 17 February 2013, 01:17:23
Sounds like half moons on cam cover - have you changed them recently?
see other thread (major oil leak)  :y
Yes, and like others suggested in the other thread Symes, it could well be a badly fitted half moon in one, or both, of the cam cover gaskets.
I had the same when I didn't fit the one on the right hand (passenger side bank) properly due to the engine lifting bracket getting in the way.  Oil poured out and I was smoking so bad I had people asking me if my car was on fire! ::) ::) ::)
Worth checking Symes with a mirror and your fingers, and just feel if the half moons are really in place and firm. :y :y
Do not scarp your beloved miggy yet!!!
if you meant scrap---NEVER happen--found problem-1 half moon and seal on oil cooler banjo bolt :o Fixed it 8) 8)
The half moon problem was as expected! :y
martin42
easy mistake to make if its your 1st time  :y
symes
Quote from: martin42 on 17 February 2013, 19:47:39
My A***   done  about 10 migs mate- Typical though isn't it-Still glad not someone else's miggy-What surprised me was seal on banjo bolt going south  :o Still at least bottom of miggy wont rust ;D ;D  covered in oil ;D
Was the oil cooler banjo bolt loose mate?  Seals on that are two solid copper washers one above and one below banjo - unlikely to leak if banjo bolt tight.
Webby the Bear
RIP Paul Lovejoy
Quote from: symes on 17 February 2013, 21:27:56
Yep, I had done two and on the third..............!!! :P :P :P :P :P
