Author Topic: Codes..  (Read 3485 times)
tidla
  • solihull
Re: Codes..
« Reply #15 on: 22 February 2013, 21:24:28 »
Did you change the oil yourself last time?
Might be worth putting replacing the engine oil and filter again, possibly using a slightly thicker grade(hot climate)
Andy89
  • Norway
    • 97 3.0 MV6
Re: Codes..
« Reply #16 on: 22 February 2013, 22:06:53 »
When checking the oil pressure, take out fuel and ignition relays so the car doesn't start with low pressure at least, you should be able to get enough pressure by turning the engine on the starter motor, just don't turn it too long on the starter.
If that doesn't help, change oil and filter as said, and if that weren't to help, I would take off the lower sump and check if the pickup is blocked.
pacman13
  • hitchin, hertfordshire
    • Vauxhall omega 2.0 16v
Re: Codes..
« Reply #17 on: 24 February 2013, 15:12:40 »
Yes i changed the oil myself using gm oil 10 40w and gm filter as well. :y Got the mechanic coming round to me this week as he was the one who worked on the head gasket etc.
