Lada Niva available again...........
Started by Vamps, 20 February 2013, 21:59:49
Quote from: acope on 24 February 2013, 20:57:31
Quote from: Vamps on 23 February 2013, 22:04:43
Quote from: Tilbo on 23 February 2013, 21:51:07
A colleague at work had a Ssangyoung Musso  4x4 terrific looking vehicle, but had difficulty getting genuine parts for it had to wait ages for brake items, sold it recently & purchased a large Citroen to tow with.   Took a huge loss with the Musso .
I have heard that too, but not said anything..... :D :D  I think he has the Rexton, if so the Engine and auto Gearbox are from Mercedes so parts for these are OK........ ;)
Dont knock the Ssangyong, admittedly the 2.7td has had its share of problems,which are mainly electrical based, but the 2,9 Rexton, which is basically a musso with a new suit on is a very capable vehicle..merc engines which run for ever, and can run on vegetable oil which is about 50-60p cheaper than pump prices.
The Ssangyong owners club ( of which I am a mod) has a brilliant set of knowledgeable members (similar to the guys on here) and an extremely good list of parts suppliers for both new and 2nd hand parts.
Can they? I was told no, more info please, merc 2.7 in the Jeep 55 reg..... :y :y
acope
Merc 2.7 engine fitted in the newer Rextons............ NO.. :'(
Merc 2.9 as fitted to the early Rexton and Musso..... YES.. :y
you can not run any Common Rail Diesel (CRD) engine on veggie
ALAN
2boxerdogs
Thanks for the info, but I will stick with the normal stuff ! Not sure how many cylinders will check through the literature I have ,have read a lot of stuff about not using supermarket diesel in this engine so have always used BP.
2boxerdogs
Hi, sales brochure engine spec.. 4 cylinder DOHC/2902cc..Hyundai Terracan.As I said I have been told by other owners that this is a Mercedes engine, whether this is true or not I don't know, no details about fuel pump/system.
acope
#34
Hi, not sure about that one, "normally"as long as it has the BOSCH pump its ok to use veggie, but think it requires abit more checking before veggie was used.
2nd thoughts..thought Hyundai used their own engines...hmm not sure
The 5 CYL version is called the OM602 engine, same engine as in the earlier Sprinter vans
ALAN
scimmy_man
I had a niva in the eighties,  good off road, but terrible on road, I once missed a turning completely as the brakes were that bad,
I remember when you parked, everything you had turned on radio, wipers, heater fan etc had to be turned off again, nothing was wired from the ignition but the engine.
the starter motor packed up, the dealer said it was a 3 hour job to swap, I did it in an hour with long socket extensions, he offered me a job.
