How long should it take to replace the rocker gaskets on a V6
Started by Vamps, 20 February 2013, 22:19:18
Undo 2 bolts on pug , 4 cups of tea and bacon buttie , 10 minutes  :P :P ;D
I should add that I often find myself repairing other bits when doing jobs which can increase the time (e.g. I have found the fittings snapped off the rear of the breather bridge, or the coolant pipes wrongly routed) which can add to the time.
Quote from: EMD on 21 February 2013, 10:34:11
....and changing the coolant temp sensor (10 times)?  ;D
Plus breather and throttle clean up
Quote from: Marks DTM Calib on 21 February 2013, 10:37:19
Not got that far yet , must get a book of lies  :( Or some redex  ::)
Redex wont clean the throttle body and breathers even on an SPi setup  ;D
scottambrose
having done mine 3 times the 3rd time took me an hour and a half. as id already cleaned the breathers. its a doddle once youve done it before :y
Quote from: Marks DTM Calib on 21 February 2013, 10:40:39
Indeed. That's what the wife's an old toothbrush is for  :D
Yasmine Lee
autodata says 1.9hrs for both rocker gaskets and 0.5hrs for the breather work
henryd
Quote from: Yasmine Lee on 21 February 2013, 11:14:45
Autodata's times are a good guideline but they assume that everything undoes as it should and there are no other issues such as split vacumn/breather hoses etc :y
other rides
I spend about 3 hours doing the cam cover gaskets, breathers and throttle bodies
bored bigyin54
a 4 pot is easy  ;D ;D
Quote from: Marks DTM Calib on 21 February 2013, 08:13:31
1.5 - 2 hours with a breather clean.
A compitent mechanic should no take much more than 0.5-1 hour more than this as a first time.
Really depends how dirty/clogged up breathers are - took me ages to clean breathers on my old Elite the first time I did them, really clogged up.
bored bigyin54
has it got an engine  ;D ;D ;D
Quote from: bored bigyin54 on 22 February 2013, 16:46:03
Yeah 4 pots like yours , and a pattern rocker cover  :P :P :P ;D
martin42
