Had a Focus one day and it's already broken!
Started by Steve Brookman, 21 February 2013, 18:43:19
serek
Quote from: Steve Brookman on 21 February 2013, 20:00:25
Thanks Josh I found it quite fast enough.
My brothers ST 225 is a cracking car to drive-even before he had it chipped. What makes a 225 special is the massive torque and the sound of the 5 pot engine. Only downside is the 20mpg.
Regards
Steve
those volvo engines are good  :y
Steve Brookman
Checked this evening-plug compartment has water in it presumably from valetting as the engine bay looks like its had the steam cleaner on it. Plug leads were wet. Got as much water out using my airline and a rag. Left leads off tonight to let water dry out and will give it a go tomorrow.
Cheers
Steve
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
henryd
Quote from: Steve Brookman on 22 February 2013, 19:22:29
Cheers
Steve
If it's still a bit damp in the morning run the engine up to temp then switch off and pull the leads again,hopefully the heat in the head will dry it out completely :y
other rides
Quote from: TheBoy on 21 February 2013, 19:42:54
No, its not (nice). How Ford managed to get so little power out of that cc, and deliver that power so badly, is a work of art. On the upside, it won't go fast enough to show up how badly the chassis handles.
Depends what cams are in it. The 1.8s ranged from quite good to "useful only as an offensive weapon". Fit the cams from the 2.0 and they are OK. Good for 130 BHP on standard induction and around 150 on something more interesting.  ;)
Quote from: Kevin Wood on 22 February 2013, 21:19:28
I was referring, of course, to the standard Focus engines fitted to lower end models, like the 1.6 I had, and the 1.8 that Mrs TB's brother had, on a works lease scheme when they were Ford employees.
Both were absolutely demolished in a straight line by a K series powered 1.6 Rover 25 (we tried ::)), which is a larger car. Even more demolished when shown a corner.
I have heard the Zetec is quite tunable (as is the K Series, come to that), but to me, in the Focus, just felt it lacked torque, esp low down.  I guess in a 500kg kit car, thats not so much of a problem, and trying to raise the rev limit is more productive?  Aren't you getting around 200bhp from your 2l?
The Zetec E 1.6 was a total dog. A bodge to replace the CVH, they crippled it to try and make it similarly gutless and cheap to insure. Worst of both worlds - power all up at high revs and not much of it. But they clearly couldn't be @rsed to design a different engine for the base models.
The 1.8 came with various different configs from a crippled 105 and 115 to 130 BHP. Guessing the Focus got the 105 or 115?
It's been so long since I've driven one in standard form that I can't remember (thankfully). Never driven a Focus at all, AFAIK.
Of course any K series car would probably 30kg lighter in the engine department for a start.
Steve Brookman
Just an update.
Took it to Ford dealer where brother-in-law works and they said the water in the plug wells was antifreeze which was coming from one of two small core plugs. The mechanic said it was a fairly common problem. They'll fix it and replace the coil pack at the same time.
Cheers again
Steve
Previous
I couldn't believe how much fuel the 1.6 Focus I had as a loan car drank. Honestly the 3.2 uses less.
Maybe there was something up with it.
Quote from: VXL V6 on 23 February 2013, 18:04:43
We used to get about 30mpg from ours.
martin42
oh dear i get 40-45 mpg in the escort 1.8 cabby ;D ;D
Quote from: martin42 on 24 February 2013, 10:13:39
Miss Daisy, clearly ;D
That said, Ford did make the Focus out of the heavier material call steel, rather than FeO that they made the Escort from :P
