corsa c misfire
Started by spud1990, 23 February 2013, 21:06:29
Webby the Bear
Quote from: Marks DTM Calib on 26 February 2013, 21:47:31
Quote from: Webby the Bear on 26 February 2013, 21:40:51
I'm confused  ::)
This thread was talking about a misfire and various sensors... then a load of pics of what looks to be gummed up valve cover and a bent oil filter (?).
Can someone explain what's happened :)
So, some oil contamination (water), this has clogged things up and the oil pump has collapsed the oil filter its so clogged.
Oil filters normally collapse due to crudd and not Mayo hence question about service history
i did wonder about the water contamination but thought it looked more like mayo as opposed to the stuff built up in that valve cover  :y
thanks for explanation though  :y :y :y :y
RIP Paul Lovejoy
spud1990
look this up on google might explan it for you all. Vauxhall Corsa Misfire Detected P0304 P0302 P0301 P0300 Fix ...
http://www.bargainspares.com/vauxhall-corsa-misfire-detected...
6 Feb 2013 ... p0304 cylinder 4 misfire detected corsa astra vauxhall 300x206 ... Anyway, I
digress as always – This misfiring Vauxhall corsa is a 2001 Corsa C 1.2 1199cc
... multiple random misfires detected P0300 corsa 300x236 Vauxhall ... coppy this and put into google it will come up.
spud1990
im not sure where the water has come from. she said  it was not using any water. i will keep you all posted  :y :y
That's the worry...that's a lot of water and not something seen in your link.
Oh yes, the plastic will be from the timing chain guide
henryd
Quote from: Marks DTM Calib on 26 February 2013, 22:05:52
Front timing chain cover gasket behind water pump can let water into sump,seen a couple of headgaskets changed on these needlessly :-\
other rides
tidla
#35
Quote from: henryd on 26 February 2013, 23:02:04
Worth a clylinder leakage test to discount head gasket and coolant pressure test to prove timing cover gasket leak.
edit. (noted no water loss?, even if it was entering the sump via water pump seal, it still a loss of coolant and possible increase in oil level?)
henryd
Quote from: tidla on 26 February 2013, 23:11:01
Looking at the pictures I find it hard to believe that there is no water loss unless some dopey dipstick has added water via the filler cap by mistake ::)
other rides
tidla
Any updates? Like to see a story thru.
spud1990
good news. i blew all oil ways through and cleaned the engine. put it all together and problem solved. no misfire. iv done 150 miles in the car and there is no water loss. so glad its fixed. :y :y :y :y
tidla
So far so good.
So the cause is the plastic chain tensioner breaking up which then blocks the oil way to the head which starves the tappets of oil.
going to read it again.
1, The knock sensor causes the misfire from the noise created from the tappets?
2, valves opening late/closing early due to hydraulic tappets empty?
spud1990
there was no plastic in the sump. just alot of shit and small pieces of oil filter. i took out the tappets and blew the oil ways out. had alot of small pieces of paper from the filter come out. read it again iv looked at it a few times. glad it has solved the problem. :y :y :y :y
