An explanation about why changing ATF MAY be a bad idea if never been done...
Started by Webby the Bear, 24 February 2013, 10:01:33
Quote from: ffcgary1 on 24 February 2013, 17:12:32
Dont VX recommend a fluid change every 70,000 miles, i seem to remember seeing this somewhere. :-\
It is in the OOF recommended service intervals 60k iirc. Vauxhall say the box is sealed for life, bless them.
tigers_gonads
Ok question time before I go and spend 50 squid on 2 gallon on ATF and a can of brake cleaner.
My new shed has been neglected for the last 2 years.
Engine oil was like tar but now sorted.
Gearbox is very reluctant to change up when the oil is cold.
Also it had a p1700 code which seems to have disapeared over the last 300 miles of my use.
Ode meter says 125 K
Do I drop the gearbox sump and do a total oil change and clean the filters out while i'm in there OR do I just top it up with fresh ATF and see how it runs ?
Never had a auto box before so this is a bit of a learning curve.
Also do I need a gaskit for the sump plate or is it a case of silicon ?
You can't change "all" the ATF by just dropping the sumps/filters, only about 1/2 gets removed as the torque convertor and cooling pipes are still full. actually emptying the system takes a quite a bit of faffing I believe !!
I did the "sump drop change" on mine at 85000, as its use for towing a lot .. and I'm very pleased with the result... changes were smoother, quieter and seemed to be earlier as well .. but that might be wishful thinking !!
A favoured method of changing the ATF on Merecedes forum iirc is to disconnect the outlet pipe from the transcooler and put the end into a suitable container.Then,start the engine and pump new ATF into the transmission.Job is complete when new ATF starts appearing in the container,rather like bleeding brake fluid.
I wonder if thres any reason this cant be done with the Omega autobox ?  :-\
TG,if the car has been a tad neglected and the box is a bit grumpy I would change the ATF personally.
Iirc there is a gasket,but its fine to use sealant when replacing the sumps.
Quote from: tigers_gonads on 25 February 2013, 14:32:46
New gaskets and filter are about £35 from here http://www.jpat.co.uk/
Change it. That's twice the recommended mileage.
I prefer gaskets myself, but an instant gasket goo will do fine.
I know you don't mean silicon btw, but just to be sure, silicon is a no no.
Sealing the scuttle up maybe, but other than that, no. Just no ;)
Quote from: chrisgixer on 25 February 2013, 16:53:14
What about around the bath :P
Quote from: Elite Pete on 25 February 2013, 16:54:28
Indeed. Scuttle drain. Exactly that. ;) ;D
I'd chnage it.
Note, the TCM holds 1st gear longer when cold, to heat the cats up faster. ECO crap for the tree hugging hippies who really are a waste of valuable oxygen.
tigers_gonads
sassanach
Quote from: Albitz on 25 February 2013, 14:55:52
thats the method i use,works very well but uses a fair bit of atf
I had a full oil and filter change on the Jeep, Merc Autobox, and noticed an improvement in gear change time and smoothness...... :y :y
If its unknown, I think I'd like to have the sump off anyway, check and clean the magnet, and search for bits of thrust washer....
Yes I'd like the sumps off, but I'd also like to get ALL the atf out too :)
