Author Topic: No sat nav signal after lpg install  (Read 3081 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« on: 25 February 2013, 12:02:10 »
Right all I can think is I've disturbed something while doing lpg. Radio reception hasn't changed just no satellite reception. Things I've done. Removed traffic master box and switch and i had rear shelf out. Any ideas?
Re: No sat nav signal after lpg install
« Reply #1 on: 25 February 2013, 17:43:39 »
Had radio out, or tugging on wiring behind it?
If so, *IF* you're really lucky, nav aerial may just have dislodged from cage. If so, get a lotto ticket.  More likely the shitty GM wiring is as predictable as always. Strip the plug, centre core of coax would have come adrift. Resolder. Bit fiddly.
doz
  • Southampton
« Reply #2 on: 25 February 2013, 17:54:44 »
Not disturbed the stereo apart from unplugging the traffic master above the peddles. Could it be anything to do with the aerial amp under the rear shelf? Just wondering like
    • 530D M Sport, 330i Coupe
« Reply #3 on: 25 February 2013, 20:26:04 »
Aerial cable for Nav runs from base of antenna on roof via a blue plug and socket about 2 inches from aerial base, down C pillar, along the plastic sill cover via a join in the multiplug at the kickpanel and then in the loom around the bulkhead area and into the back of the Headunit.
« Reply #4 on: 25 February 2013, 21:22:39 »
Indeed. Can't see anywhere OP would have disturbed it  :-\
« Reply #5 on: 25 February 2013, 21:26:01 »
Possibly pulled it at bottom of C pillar when removing shelf ?  :-\
doz
  • Southampton
« Reply #6 on: 25 February 2013, 22:27:22 »
Yep that's a possibility. For some reason removing the rear shelf on this car is a right arse job.  :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 26 February 2013, 21:33:37 »
There's definitely a nack to it.  ;)
