Whats that burning smell ?
Started by omega3000, 25 February 2013, 23:06:35
Quote from: Elite Pete on 26 February 2013, 09:22:37
It's French, it's supposed to smell ;D
::) :P
Quote from: ozzycat on 25 February 2013, 23:56:06
steve the gunk burning smell takes weeks to go away  i know mine is still smelling after a month
I did think that kev but the gunk smell surely shouldnt be coming inside the car  :( I dont even know if its got a pollen filter  ;D :(
Sod the smell, find out where the coolant is going.
The fact there is no mayo on the dip stick means jack, it only tells you there is no water getting in the oil.....it could be going elsewhere either externaly, internaly or into a pot.
The burning smell is probably the electrics, standard fit on french stuff  ;D ;D :y
Quote from: Marks DTM Calib on 26 February 2013, 09:59:47
The bruning smell is probably the electrics, standard fit on french stuff  ;D ;D :y
Thats ok then  ;D
I will check the water level again today , if its used any more then ill know there is a problem  :y
ozzycat
Quote from: EMD on 26 February 2013, 09:55:19
::) :P
through the air vents steve
long live the magic tree
its good to be back
Still burning but not caught fire yet ... seems to have stopped smelling as bad as it was , wont be using that Gunk on the engine again  :( Topped coolant up but only about half a cup , this is the coolant settling to its proper level after it was changed  :) Cant wait to see what condition the starter motor is in , if its anything like the engine it will be covered in goo  :(
ozzycat
that pug must be costing you a fortune steve :o :o
its good to be back
Quote from: ozzycat on 28 February 2013, 17:36:02
Not really kev , just done a full service and 2 new driveshafts and exhaust £80 all in , oh and the sensor for ecu £10 . Just got to inspect and clean the starter motor , so might have to replace that for £40 . Wear and tare items really . Hopefully get it sorted at weekend  ;)
