Author Topic: Fuel pump/injector relays  (Read 5626 times)
Re: Fuel pump/injector relays
« Reply #15 on: 05 March 2013, 12:15:49 »
Fuel pump doesn't run without a signal from crank sensor ;)
Car started on several occasions when the relays were pushed/pulled around but despite them being replaced with new problem was still there.
Fuel pump has now been replaced and car started.No fault codes are present,although slightly worrying is when I connected the old pump up to 12v it ran but I am suspecting it was getting a tad "lazy" and would stick.
Perhaps you have found the fault but the fact the old pump still runs fine makes me think you should be carrying a spare crank sensor ;)
« Last Edit: 05 March 2013, 12:23:42 by Lazydocker »
