Author Topic: my omaga only starts off a jump start  (Read 3520 times)
nuttytart
  • west midlands
    • omega
« on: 27 February 2013, 22:58:59 »
can enny one help my can well only start off a jump start
Re: my omaga only starts off a jump start
« Reply #1 on: 27 February 2013, 23:00:08 »
Welcome to the forum :)
New battery needed ?
nuttytart
  • west midlands
    • omega
« Reply #2 on: 27 February 2013, 23:06:08 »
thanks had one and a new alternater soz a bout spelling  :-[ :-[ :-[ :-[
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #3 on: 28 February 2013, 03:08:22 »
sounds like the battery leads connectors to me knackered so not charging right, check if they getting hot when running
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
flyer 0712
« Reply #4 on: 01 March 2013, 18:06:56 »
Although you have fitted a new battery is the A.M P  hour correct as half the time suppliers give out the wrong battery..i speak from expierence....i had to change mine through the same thing....ended up changing the starter motor...that cured it   :y
nuttytart
  • west midlands
    • omega
« Reply #5 on: 02 March 2013, 14:00:38 »
thanks every one well try wot u said  :y :y :y :y
nuttytart
  • west midlands
    • omega
« Reply #6 on: 11 March 2013, 15:36:59 »
well tryed every think car still playing up so its up for spares or repear  :'( :'( :'( :'( :'( :'( :'(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #7 on: 11 March 2013, 15:41:15 »
Where abouts are you nutty ?
What engine ?
Any lights on the dashboard ?
Any codes stored ?
Maybe one of the local members could pop round for the offer of a few beer tokens
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #8 on: 11 March 2013, 15:50:41 »
Shame to break it unless you are absolutely of that mind. I am Worcestershire by County and West Midlands by Post Code. I'm not a professional mechanic etc but have kept my Omega going (hands on) by using OOF and its resources. Do send me an email if I'm local enough for you to have another look. I notice active 'West Midlands' members on the site who may also see this before you decide.
adey2
« Reply #9 on: 11 March 2013, 16:10:42 »
and im only nuneaton so plenty of us around to help
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #10 on: 11 March 2013, 19:27:44 »
check to see if your earthing strap is all good and clean.  :)
P-son
  • South Sweden
    • Omega B 3.0 Caravan (FL)
Re: my omega only starts off a jump start
« Reply #11 on: 06 January 2014, 14:33:12 »
Hi !
I have a similar problem with both my cars...
Car 1:
2002 2.2 Petrol Sedan
Sometimes theres no crank....
good battery, over 12v doesent go below when crank doesent work, it doesent eaven try to crank, evetything else works.
To get it started, jumpstart using other car och simply connect battery-charger for a few minutes (so that voltage get to ~14v) then it works fine !! And when I say Batterycherger I mean a tiny-winy longterm intelligent charger (c-tek) nothing that have boost function.
Could it be the solenoid that it being old ?
Car 2:
2000 3.0 Petrol Estate
9 times out of 10 no problems.
But every now and then its the same thing as car 1.
But here its not the same troble getting it started after.
Simply put ingnition of (and key out), switch on headlamps and try again and if fires up.
WTF !!
Same problem on both do you think ?
