Author Topic: Is there something wrong with my boiler?  (Read 8271 times)
Kate
  • Cornwall
    • Drives people mad
« on: 28 February 2013, 19:21:04 »
Hi all.
I've just looked at my last two gas statements and got a real shock. Since the 4th December I've used nearly £250 worth of gas.
Do you think I have a problem with my boiler?
The meter readings are: 4th December 6881, 21st Jan 6975, 21st Feb 7093, today 7125.
I have an imperial meter. The boiler is a Worcester Bosch 25Si and I have 2kw gas fire and a gas cooker.
I'm really worried about this as I can't afford to pay this amount.
Any advice would be greatly appreciated. :y
Re: Is there something wrong with my boiler?
« Reply #1 on: 28 February 2013, 19:30:40 »
It depends how long you have it on for and at what temperature you have the thermostat
« Reply #2 on: 28 February 2013, 19:33:02 »
Mine £180 and it's only used for heating everything else is electric and its only on from 6pm until 10pm Monday to Sunday and sometimes in the day on a Sunday when we're at home
Kate
  • Cornwall
    • Drives people mad
« Reply #3 on: 28 February 2013, 19:35:28 »
Thanks Pete. Is that for 10 weeks?
STMO123
« Reply #4 on: 28 February 2013, 19:36:29 »
For the same period mines about £200. Two bed semi, gas ch and hot water.
« Reply #5 on: 28 February 2013, 19:37:40 »
Yep. Forgot to add that it does the hot water as well ;)
Kate
  • Cornwall
    • Drives people mad
« Reply #6 on: 28 February 2013, 19:39:04 »
Thanks. Mine doesn't seem too bad then.
Kate
  • Cornwall
    • Drives people mad
« Reply #7 on: 28 February 2013, 19:40:45 »
Does anyone know how much a 24kw boiler uses an hour if it's on full?
STMO123
« Reply #8 on: 28 February 2013, 19:42:53 »
It's going to get worse, Kate. I can't see any way, given the parlous state of our generating capacity, that we can survive without importing most of our fuel.
The weather will get warmer soon but, take my advice, get some money put away for next winter.
« Reply #9 on: 28 February 2013, 19:42:59 »
Try and pay it monthly, that way they work the bill out over the year, you still pay the same but it's the same each month rather that an expensive winter and cheap summer ;)
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 28 February 2013, 19:46:04 »
I do pay monthly. I was worried that they would put the payments up as I'm only paying £114 a month for both.
STMO123
the alarming man
  • medway kent
    • disco V8
« Reply #12 on: 28 February 2013, 20:03:58 »
mine was £ 200 for 10 weeks...daylight robbery :y
Kate
  • Cornwall
    • Drives people mad
« Reply #13 on: 28 February 2013, 20:16:23 »
I'm trying to minimise using the central heating at the moment.
Does anyone know whether calor gas heaters are cheap to run?
« Reply #14 on: 28 February 2013, 20:25:17 »
No Kate, they will cost a lot more to heat the flat...... ;)
Pages: [1] 2 3 4  All   Go Up
