Author Topic: rear headamp level sensor wiring  (Read 9904 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« on: 04 March 2013, 22:26:17 »
while jacking my car up the jack slipped and caught the level sensor the arm looks to still be connected the only thing i could see that looked damaged was the wires going to the sensor were looking squashed against the wish bone is the section of loom available or would it be best to repair it ?
2001 MV6 3.2 manual been converted from 2.6 auto
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: rear headamp level sensor wiring
« Reply #1 on: 04 March 2013, 22:35:49 »
Repair. From Memory it is on piece back to the controller in the O.S. Wing. Only 3 wires. However if you haven't had the fault come up on the display you may of got lucky
bigtow
  • rochester kent
« Reply #2 on: 04 March 2013, 22:49:53 »
thats how i know i have damaged something as i have the fld/vision message of doom  :-\
doz
  • Southampton
« Reply #3 on: 04 March 2013, 22:54:14 »
Took me bloody hours to suss out what was wrong with mine. Had two broken wires touching together getting me right in a pickle. Best break out the soldering iron
bigtow
  • rochester kent
« Reply #4 on: 04 March 2013, 22:59:39 »
so a couple of bullet connectors and sticky tape wont work then ? lol ;D ;D ;D ;D
doz
  • Southampton
« Reply #5 on: 04 March 2013, 23:03:39 »
Only if you use 2.5 mm twin and earth house wire  :P :P
bigtow
  • rochester kent
« Reply #6 on: 04 March 2013, 23:06:16 »
dont tempt me  :D
kooky_guy
    • '01 Omega 2.6 GLS Estate
« Reply #7 on: 06 March 2013, 16:08:29 »
Excuse the thread hijack - I picked my car up from the garage yesterday - they replaced the thermostat.
It immediately showed this error as soon as it started. Anything obvious for me to check?
« Reply #8 on: 06 March 2013, 16:11:04 »
Often the arm pops off the sensor on the front nearside wishbone.  :-\
kooky_guy
« Reply #9 on: 06 March 2013, 16:23:47 »
Would they have been anywhere near this to replace the thermostat? It did takle them a week, I suppose...
The worrying thing is that the fault seems to pop up intermittently. or is that normal for this fault?
« Reply #10 on: 06 March 2013, 16:41:34 »
Nowhere near  ;)
Mine came on & stayed on till I replaced the front sensor years ago & hasn't been back on since. Try a squirt of switch cleaner in the plug/socket  :-\
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #11 on: 06 March 2013, 16:47:51 »
GLS won't have level sensors will it?
TuBy's new whipping boy.
« Reply #12 on: 06 March 2013, 17:03:50 »
I suppose it must have if the field vision warning is on .....  ;)
« Reply #13 on: 06 March 2013, 17:10:23 »
Doubt it. OP`s profile states GLS 2.6. No such beast, must be a typo (or typographical error for you Andy) :D
« Reply #14 on: 06 March 2013, 17:49:45 »
Now come on Rob! I only pick up on bloody Americanisms & those that are plain stupid!  ::) ::) ::) ::)
