Author Topic: LPG FILLER ISSUES  (Read 2157 times)
Marie
    • 2ltr LPG Estate
LPG FILLER ISSUES
« on: 05 March 2013, 20:53:56 »
 Hi guys
well wonder if you guys can advise me further.
Fault:
i have notice that over the last month that after filling the car up with gas when i release the nosel the amount of gas that escapes ( pressure release) has increase to the point i burnt my hand today  :'( didnt move it out the way fast enough and it was bad enough to splash on my trousers.
now before you ask i have tried several different garages and different pumps to to ensure it not the garage side. ut im sure its the car.
hubby seams to think there is a seal in the filler point im not sure i did have a look at it while stuck in cornwall this week and lubed it but thats all due to no tools
is there a seal or do i need to replace the conection? can i get spares
thanks for reading guys  :-*
Re: LPG FILLER ISSUES
« Reply #1 on: 05 March 2013, 20:56:08 »
Thats some release pressure if its splashing on trousers  :o
What size is the tank & how many litres are you putting in? Tank rotated to right position?  :-\
« Reply #2 on: 05 March 2013, 20:57:34 »
There is a seal in the filler itself. Probably as well to replace entire filler - should be easy, and probably about £25
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 05 March 2013, 21:06:17 »
Hi guys
Fault:
Marie,you say you are down in Cornwall at the moment,if you are down in the Helston, Falmouth area there is a garage called Autogas at Longdowns who are LPG installers,I can't vouch for there work but they should be able to source you the parts you need to fix it yourself if need be :y
other rides
Marie
    • 2ltr LPG Estate
« Reply #4 on: 05 March 2013, 21:09:13 »
i know thats what i thought tank size is 45 ltrs never normall get more then 40/41 ltrs in it.depends on outside temp try and do it when its cold out. although today was mid day and only got 37 ltrs in her
cool and the best place to get a replacement is ? ebay?
Henryd i was im now just at home in lincolnshire thank god that was an epic journey and saw a couple of migs on route none from here though i thinks
« Reply #5 on: 05 March 2013, 21:17:36 »
tinley are expensive, but seem to have good stock and fast delivery
« Reply #6 on: 05 March 2013, 21:22:43 »
Yep, guessing the gas in the filler line is escaping, and there should be a valve in the filler to prevent that. As said, just replace the filler. :y
Marie
    • 2ltr LPG Estate
« Reply #7 on: 08 March 2013, 20:36:36 »
just a quick up date.
ordered a new filler complete from where TB recommended fitted it yesterday and filled up today.
well  what a difference definately worth the money and definately need replacing.
now i dont have to worry about issues during filling again :)
