auto conversions....
Started by 2woody, 05 March 2013, 22:08:33
Quote from: VXL V6 on 06 March 2013, 10:08:28....
Think it's well known on here that I always left foot brake when i'm in an auto.
Likewise.  ;)
Quote from: VXL V6 on 06 March 2013, 10:08:28Feels un-natural now to use the right foot to brake in an auto.
[standby to get flammed mode=on]
I too default to left foot braking. The only time it has been a slight problem was when I frequently drove a manual & tried left foot braking in that...... the clutch pedal doesn't slow the car very well.  :o  ;D  ;D  ;D
Quote from: Andy B on 05 March 2013, 23:09:14
Quote from: tunnie on 05 March 2013, 23:07:10....
Heard of it, but 99% of auto drivers don't do it.
What does left leg do in an auto? Sod all!
I'm willing to bet that there are more than that ........ I do - but I might have already said that a few times before  ::)
I don't know anyone who drives an auto with just one foot. Two feet and two pedals makes perfect sense. Especially when you shouldn't be using both pedals simultaneously.
SMD
The gas and brake pedal are too close together so it isn't the most comfortable driving position  (not that I can brake with my left foot)
Quote from: SMD on 06 March 2013, 12:13:03
The gas and brake pedal are too close together so .....
Are they any closer tan any other car ...... manual or auto?  :-\ :-\ :-\
Quote from: SMD on 06 March 2013, 12:13:03(not that I can brake with my left foot)
Practice makes perfect.  :y :y :y
Use your right foot to brake and just follow with your left ..... you soon get the hang of it  ;)
Only time I do left foot braking is when I use the brake as a clutch, for times like ramps when you need little more revs.
I find it tricky though as left foot is used to stomping on the clutch, auto just makes me more lazy. Lifting left foot is far to much effort  ;D
Quote from: tunnie on 06 March 2013, 12:35:08
Exactly! If you ever want to be able to driver a proper manual car properly again, then it's a silly habit to get into, IMHO. Keep each foot attuned to the job it's supposed to be doing!
I know the Omega's manual setup isn't the best in the world but who on earth would go to the trouble of "upgrading" it to auto? :-\
Quote from: Kevin Wood on 06 March 2013, 12:56:06
even if I dont have the left leg, I would tie a pice of stick and still I would drive a manual.. ;D
the only exception would be a smg box with f1 pedals.. :)
which costs more than the car when donald :-\
Quote from: Kevin Wood on 06 March 2013, 12:56:06....
Exactly! If you ever want to be able to driver a proper manual car properly again, then it's a silly habit to get into, IMHO. Keep each foot attuned to the job it's supposed to be doing! ....
Having had a driving licence for as long as you've been around, I can manage to drive a manual properly if the occasion arises .... as I suspect other left foot brakers here will be able to do too.  ;)  ;)
Quote from: Andy B on 06 March 2013, 13:05:37
That's fine, then. ;) I know I couldn't, and that I'd find myself going for the wrong pedal with the wrong foot or with the wrong level of subtlety. It would probably happen during a moment of panic when doing the right thing was vital. I find simply disabling the left foot and carrying on as normal with the right in an auto works for me, but that's just me, hence the IMHO.
Quote from: Andy B on 06 March 2013, 12:16:41
Have you driven a 106 , pedals are designed for very girly small feet in high heels  ::)
Quote from: EMD on 06 March 2013, 14:05:19
Usually when I hire a Villa in Portugal or Greece you get some little FWD box like a 106, often I go for the clutch pedal and because my feet are so big, i clip the brake some times.
Usually to the annoyance and surprise of MrsT, not to mention myself!  ;D  ;D
Quote from: tunnie on 06 March 2013, 14:26:12
Yep doing that all the time  :( Have to look down at feet to make sure they are on the right pedals when setting off  :D Will be glad when i get the car that really suits my needs , for now ill have to make do  :(
I never left foot brake in an Auto, right foot only  :y.
