Dead Merc ....
Started by Sir Tigger KC, 07 March 2013, 17:19:50
Quote from: Lazydocker on 07 March 2013, 21:46:31
Quote from: Albitz on 07 March 2013, 21:06:30
Been running my Cavalier on 100% veggie almost all winter.During a couple of the coldest weeks I mixed in 10% petrol mixed fuel. ;)
Fixed that for you :-X :-X :D :D
Pitty you are so far away.... ;)
Deliberate mistake in case it may have been unwanted advertising for you. ;)
Quote from: twiglet on 07 March 2013, 21:18:24
Are you using new or waste veggie oil mate?  If the later, how are you filtering and de-watering it?
No it's spanking new oil direct from Costco.  :)
The Merc lives!!  :y
There's a slight diesel leak from one of the injector pipes at the pump, not from the pipe itself but from the connector on the pump.  I'll see if I can tighten it, but it's not a hex knut but looks like a cog with lots of little teeth, must be a special tool...  :-\
It must have let air in whilst at rest...  :-\
twiglet
Quote from: TiggerHayes on 08 March 2013, 16:01:00
The Merc lives!!  :y
Good news.  :y
As you probably know, small leaks that allow air to be drawn into the system can go unnoticed when running on diesel, but can be a real killer when running on veg.  Get that leak sorted, and do a thorough check of the whole fuel system right back to the tank.  :y
As you are running SVO, you won't have the problems with filtering and de-watering I mentioned either, but I would still recommend that you change your fuel filter regularly and keep a spare one in the glovebox along with the tools required to change it.  That's got me out of trouble on several occasions.  :y
Thanks Twiglet,  I'm back on diesel for the time being.  ::)
It turns out after a bit of research that what I thought were connectors on top of the injector pump are valves and it's a common thing for them to leak.  They have an O ring and a crush washer, I guess that the Veg oil was the last straw which popped the seal.....  :-\
Anyway, new set of seals ordered from friendly Merc dealer, a special tool from ebay and I'll have a crack at it soon!  :)
