Author Topic: bent valves.  (Read 5932 times)
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
bent valves.
« on: 09 March 2013, 00:31:35 »
O.K. problem is not exactly as the heading indicates, but is related. After the timing belt 'let go' I have some seriously bent inlet valves, remedial work is well under way, but. When this happened, it was obviously subsequently that there was no compression at all. My predicament now is, before wasting yet another ridiculous amount of money for nothing, 'would the valves have clouted the pistons hard enough to move some ally and trap the rings in their grooves'? It is fair to say that the valves have left their mark on the crowns, but have not caused indentations. Of course I am aware, ' well! It is possible'. But I am trying to weigh up the probability and make a decision on continuing or not ?? Any advice much appreciated...  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Re: bent valves.
« Reply #1 on: 09 March 2013, 01:18:53 »
Unlikely unless indented at edge of piston ;)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: bent valves.
« Reply #2 on: 09 March 2013, 02:09:06 »
Unlikley but a possability, more probable is the valve guides may well be shagged, see that quite a few times. repair it mate you know it will be worth it, its a miggy. :y
Jaguar XJ6
Re: bent valves.
« Reply #3 on: 09 March 2013, 07:57:58 »
New or used engine? (£1700 on trade club I noticed) £500 odd on eBay or a breaker.
2woody might have a spare used one? Unless he's found a home for it of course.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: bent valves.
« Reply #4 on: 09 March 2013, 08:27:04 »
if your looking for engine got one here.
http://www.omegaowners.com/forum/index.php?topic=108695.msg1360576#msg1360576
 still got it.
« Last Edit: 09 March 2013, 08:32:39 by biggriffin »
Hoof'land storeman.
Re: bent valves.
« Reply #5 on: 09 March 2013, 10:02:49 »
Unlikely to have had bottom end damage to worry about, but it will need visual inspection to confirm.
Jusme
    • Lexus LS430
Re: bent valves.
« Reply #6 on: 09 March 2013, 10:28:10 »
Many thanks for input fellas. There is only slight marking on the pistons, but as I have already thrown in excess of £2,500 at this engine, (looooong story.) I needed to know a general concensus of opinion before I proceeded. I already have replaced the old girl with the 3ltr Elite I am currently driving, (thank you Lincs Robert.) but the old girl runs LPG and it makes all the difference to me. Yes I could have bought another engine and had LPG added, and probably would have had change ? Isn't 'hindsight' a wonderful thing. But right now my original heads are being skimmed, having new guides and valves fitted, so I'm quite a way down the road to suddenly change direction. The decision NOT to proceed would have been if I had piston rings trapped. Although of course there is no guarantee they are not ? Well ! 'You pays your money and make your choices'... hmmmm! Now why didn't I buy that 06 2.8T Signum for £2,000 ??  :-\
RobseyMV6
  • west sussex
Re: bent valves.
« Reply #7 on: 09 March 2013, 10:41:34 »
I've just rebuilt top end many times, rare to find a damaged bottom end...
Saying that I have a nice 3.0 engine in my garage, in parts for sell plus a complete set of good heads... I'd just skim your heads and rebuild back  :y
Re: bent valves.
« Reply #8 on: 09 March 2013, 10:49:28 »
Jusme - if you are having so many issues with the engine  - £2.5k is a hell of a lot - I'd suggest trying a better mechanic.
I'd hughly recommend DLK.
I can't help but feel you are being ripped off :(
Re: bent valves.
« Reply #9 on: 09 March 2013, 10:52:23 »
I think Jusme has been given this advice many times by different people. I suspect it's the same mechanic that did the rebuild the first time a few months ago :(
Re: bent valves.
« Reply #10 on: 09 March 2013, 10:57:22 »
Yes, it has been mentioned, any of the competant mechanics on here would be a better bet IMO. Can't help with original question though, sorry.
ted_one
Re: bent valves.
« Reply #11 on: 09 March 2013, 11:14:34 »
DLK(Daz) is the man to pull you out of a hole,he did it for me a couple of years back and saved my 3.0 MV6 from the scrappy :'( with a bit of luck he may well find you an engine if it comes to that...he did for me,but it's plainly obvious you need some 'expert' help' and you really don't need to look any further than on this forum...it's all here  :y it took me a little while to realise it too ;) :y
Jusme
    • Lexus LS430
Re: bent valves.
« Reply #12 on: 09 March 2013, 12:29:46 »
O.K. 'Fess up ' time.. I hear what all of you are saying, and have heard it before, 'many times', and have whipped myself about it, (to the point that I'm beginning to like it  ;)) October 2012. Auxiliary belt 'let go', wound itself up the crank between the timing belt and pulley. Lots of lovely bent valves. (G.M. learnt their lesson after the safe engine on the Carlton.) Car was stuck in Bedford, and had to get it moved PDQ as it was outside a school entrance. Got a mate with a small one lift garage to come and look, and another mate to trailer it to first mate's garage. Contacted Daz for help with problem as he had just serviced it 3 days prior. (not related to auxiliary belt, no blame attached to Daz.)
He agreed to work on it. The bloke who usually does my Miggy was in Sicily at this time. Mate at garage told me he could do the work and would start stripping it immediately. I ended up annoying Daz as, not only had he put himself out for me, but had sourced heads as well. Then I told Daz what my mate was up to, this infuriated him even further as apparently my mate was not following correct procedure. Went to mate with advice from Daz, passed it on to him, result ? Toe to toe confrontation. Mainly about the timing belt pulley on the crankshaft. Daz had told me to tell him, ' you MUST NOT remove that pulley, in the event it is inescapable you must use a crank locking tool', this advice was echoed by Elite Pete, 'thing is Rob, if he tries to remove that without locking the crank, he will break the woodruff key'.
Went along to the garage. 'Hey Rob, I have got that pulley off but, whoever worked on this engine before has broken the woodruff key inside the pulley'. YEAH Vince, course they did???? I order a new pulley from Vauxhalls. SEVEN weeks later after scouring all of England AND Germany, 'sorry mate, cannot find a pulley'.
Steve at Omegaspares to the rescue.. Pulley ?? Vauxhalls = 0. Steve = 7 in stock.
Mate at garage asked for £580 to get heads skimmed etc, parted with £580. Work being done at very well respected T&L Engineering. 8 days later I phone T&L, 'how much longer before I get my heads back' ?? He NEVER brought them HERE mate, just came for a quote aint seen him since. Toe to toe time again.
Mate is back from Sicily and asks about problem? Thieving mate at garage suggests man from Sicily finishes job. He reluctantly agrees and puts the old girl back together.
Drive off for test drive, she ran like a dream, fill up with LPG, car won't go over 30mph??? No-one understands routing of injectors. Very much appreciated help by PM from LazyDocker. But still they can't figure it out? Take it to a local LPG installer. 'I don't do those systems, but I'll have a look'. His 'look' was to continue working on other cars while giving man from Sicily suggestions. 4 hours later, armed with a copy of instructions from LazyDocker, I show them the PM. 45 minutes later I am driving off.  :y
At this time we are getting ready to move to Lincoln. I have had the old girl back for 2 weeks. Our move is 7 days away. I pay a mate £150 to trailer my wife's Rover 75 to Lincoln so I would have a 'backup' car there. Wife doesn't drive anymore due to M.S. Rover delivered, head back to Bedford. Steady run along the A.1. nearing St. Neots strange noise from engine. Say to son, 'we'll take it real steady till we get home'. 200 metres before St. Neots slip road. " BANG" everything dies ??? Coast down to roundabout, wait for Rover trailer man to come out and trailer Miggy home. Only 10 miles. 'Another £20'. Panic sets in.
Rover now in Lincoln. Miggy dead. Cougar on the drive with no tax, no MOT, no insurance. Contact Daz again. He is still prepared to help ?? I agree to get it trailered to him 130 miles away, plus I am moving to Lincoln in 6 days time and I have all the packing to do. I hire a van so I can get about and get things done. Blo*dy hectic week, cash getting low, man with trailer is interested in my Cougar for his son, but aint got £600. I tell him that if he trailers my Miggy to Stoke I will give him the Cougar. Deal is done. The next morning the Cougar is gone. The night before trailering to Daz is due, another mate says, get it to my garage and I promise I'll sort it for you. That was mid November. Contact Daz, he is most pleased with me? I was relieved he lives so far away...  :-[ At least I was still in one piece.
Trailer man took Miggy 10 miles to garage. A £600 car for trailering 10 miles.. Now where is that invisible to me sign on my forehead ?? Collect my RD 500 from Flitwick motorcycles pay my £980 bill. Collect my son's Gilera from repairers, pay the £250 bill. Move to Lincoln, return van and pay my £250 bill. Get the Rover insured and try to settle down. Cold weather sets in, gets freezing, Rover heater decides to pack up. Park it up on the drive. Hi Rob,(lincs Robert) fancy selling me your Elite? Deal done. Back on the road. Keep trying to contact bloke with my Miggy, no luck.
February arrives, speak with a bloke with a garage next to the one my Miggys at. No-one has even opened the bonnet on your car. I asked if he would take a look? 4 hours later he phones me. 'The bloke who put this back together forgot to tighten up the bolts on the top pulleys backing plate, they have been steadily creeping forward until the belt has come off'.  >:( I can't go after the ex mate who did the job as it was a 'homer'.. Decided to take Daz's original suggestion and contacted Steve, ordered the 2x 3.2 heads he had. They arrived at the bloke's workshop. He phoned me instantly. 'Listen Rob, I have just unpacked these heads and one has been damaged, a bit has broken off, looks like someone has dropped it'? OMG...  >:( >:(  That was a week ago, and if you have got this far reading. 'WELL DONE'. But I can't go on...  :'(
Re: bent valves.
« Reply #13 on: 09 March 2013, 12:40:35 »
You have been more than reasonable with the "mate" who has been fleecing you something rotten >:( >:( >:(
Cut your losses, take the car and all bits to an experienced mechanic instead of the cowboys you have been using and get it fixed properly. Or alternatively take the LPG off of it and put on the new car ;)
Finally, I would advise a claim against the original "mechanic" who has relieved you of far too much money for it to be a "homer" (BTW, the heads rarely need skimming on a V6, even if the HG has failed :o) through the Small Claims Court. Costs about £125 for a claim of up to £5k so claim for all recovery costs, subsequent work to put it right and inconvenience ;)
In the nicest possible way... Man up and stop letting these cowboys take the piss out of you ;)
Oh, and in answer to your question, any decent mechanic will be able to make an assumption from the position of the damage as to whether bottom end damage is likely, but I doubt it will be ;) (Although I'm sure your "Mechanic Friend" will say otherwise >:(
« Last Edit: 09 March 2013, 12:42:35 by Lazydocker »
Re: bent valves.
« Reply #14 on: 09 March 2013, 13:21:26 »
Just read that long post and couldnt believe what I was reading.My patience and temper would have run out a very long time ago. :o
Lost track of where you are with it now tbh mate,but if you need a pair of heads cheap,or a whole engine minus cams and cam covers,gice me a shout. :y
