Author Topic: bent valves.  (Read 5934 times)
car5car
  • Florida USA
    • 01 Cadillac Catera
Re: bent valves.
« Reply #15 on: 09 March 2013, 14:38:43 »
Most valves are $6-7 here.
It would cost me about $250 in parts to repair your engine.
2 head gaskets, 4-6 valves, valve seals, timing belt kit.
01 CADILLAC CATERA 3.0 engine (Omega)
Re: bent valves.
« Reply #16 on: 09 March 2013, 15:36:40 »
That's quite reasonable actually, although completely irrelevant to the OP ::)
car5car
  • Florida USA
Re: bent valves.
« Reply #17 on: 09 March 2013, 18:44:53 »
I was trying to say, bent valves are not big deal. I don't read posts with 500 lines. People like say something like: I woke up around 6 AM, had cup of coffee, kissed my girlfriend........... And somewhere between 500 lines you can find 2 or 3 describing problem.
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
Re: bent valves.
« Reply #18 on: 09 March 2013, 19:59:42 »
<'I don't read posts with 500 lines'.> hmmmm. Short attention span then ? <'It would cost me about $250 in parts to repair your engine'.> Does that include transporting it to and from the States ? Thank you for your input, I feel much better now knowing that if I'm in America I can buy my valves for $2 each less than here.  ;)
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Re: bent valves.
« Reply #19 on: 09 March 2013, 21:40:08 »
Just get a set of second hand heads, full set of valves and known good guides
car5car
  • Florida USA
Re: bent valves.
« Reply #20 on: 09 March 2013, 23:48:07 »
deleted
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
Re: bent valves.
« Reply #21 on: 09 March 2013, 23:50:19 »
long live the magic tree
its good to be back
car5car
  • Florida USA
Re: bent valves.
« Reply #22 on: 09 March 2013, 23:58:40 »
What percentage of your long post is actually explaining condition of your car and repair?
5%? 10%?
Yes, I have short attention span for posts like yours.
« Last Edit: 10 March 2013, 00:03:51 by car5car »
Re: bent valves.
« Reply #23 on: 10 March 2013, 00:03:35 »
5%? 10%?
Don't worry about it car5. He's had a hard enough time so far.
Re: bent valves.
« Reply #24 on: 10 March 2013, 00:03:56 »
5%? 10%?
I found most of it relevant actually... Gave complete history of what has happened, what has been done and the current situation ;)
Got to agree with the OP... In this situation the repair cost over your side of the pond didn't really help much with his question re possible bottom end damage ;)
Re: bent valves.
« Reply #25 on: 10 March 2013, 00:04:54 »
5%? 10%?
That too... There's only so many times you can suggest someone is taking the piss :-X ::)
Re: bent valves.
« Reply #26 on: 10 March 2013, 00:08:01 »
5%? 10%?
Have to agree, OP gave a complete breakdown/history of the whole sorry tale.  USA post no help ::)
