Author Topic: wim  (Read 1243 times)
shanjon
wim
« on: 10 May 2008, 13:50:28 »
im thinking about a trip to wim but i have some queries ,
1. would it be a good idea to have new rubber all round first
2. would it throw the geometry out if i were to change wheel size after it was done, basically if i were to put standard wheels on for the geometry and then put my 18" s on would it throw it out
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: wim
« Reply #1 on: 10 May 2008, 15:39:02 »
It's not important to have new rubber fitted before having the geometry done. However, changing the will size will throw out the setup as ~I'm pretty sure they have to input the wheel size when they start the setup. :)
Dazzler
  • Haverhill, Suffolk
Re: wim
« Reply #2 on: 10 May 2008, 15:42:13 »
If your tyres are unevenly worn, ie-inside edge knackered then yes you will need to change them as this will through out the camber, as this is done weight on wheels ;)
Page created in 1.699 seconds with 20 queries.
