Author Topic: Are there air injection system codes? Who removed it?  (Read 2701 times)
car5car
  • Florida USA
    • 01 Cadillac Catera
« on: 13 March 2013, 19:38:54 »
I don't think my car needs it.
01 CADILLAC CATERA 3.0 engine (Omega)
Re: Are there air injection system codes? Who removed it?
« Reply #1 on: 13 March 2013, 20:33:36 »
Secondary air injection? Not needed, there for cold start emissions only makes no impact to car running or fuel use.
car5car
  • Florida USA
« Reply #2 on: 13 March 2013, 23:12:07 »
I checked diagram and didn't find connection between ECM and secondary air injection pump, only solenoid is run by ECM.
That means, you can throw away everything, except solenoid and ECM will not notice it.
« Reply #3 on: 13 March 2013, 23:19:54 »
Correct  :y ....... but easier to just pull its fuse.  ;) ;)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #4 on: 14 March 2013, 07:40:02 »
Which fuse is that do you know?
« Reply #5 on: 14 March 2013, 08:26:59 »
Aren't the immission laws tighter in the US of A I would check before removing it
car5car
  • Florida USA
« Reply #6 on: 14 March 2013, 10:46:44 »
There is no emission control in Florida. I think, air injection system is just a way to cheat emission control by manufacturers. Exhaust gas is just dissolved by clean air, of course pollution percentage goes down.
Abiton
« Reply #7 on: 14 March 2013, 12:02:52 »
If it was that simple a cheat, why bother to go to the trouble/expense/complexity of pumping the air in so far upstream, right at the exhaust ports? It would be much easier to arrange for the cheat air to enter further downstream towards the tailpipe, no?
It's about warming the cat(s) up quicker by a secondary combustion, so that they can burn off the hydrocarbon pollutants that are unavoidably associated with cold start.  HCs make smog, which no-one wants, unless they are idiots.  Newer solutions are better, simply by putting a cat nearer the engine, so it naturally heats faster.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #8 on: 14 March 2013, 14:36:20 »
Hence the pre cats on the later engines I assume and we all know how well that one worked.
TuBy's new whipping boy.
Page created in 0.117 seconds with 20 queries.
