Author Topic: Fault code- throttle position sensor high voltage?? x20xev  (Read 2763 times)
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
Working on the wifes x20xev (valve stem oil seals etc) and its now thrown up tps sensor voltage high. Brought on the EML and the TC light. When I plug "My Naff Code Reader" it tells me on both engine and auto box that theres a fault with the TPS. Tried another TPS i have and still the same!!
Any advice gratefully received on where the problem may lie??
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: Fault code- throttle position sensor high voltage?? x20xev
« Reply #1 on: 16 March 2013, 15:19:33 »
Sounds like you've pinched the wire while doing the head work.
PhilCavSRi130
  • GRIFFIN POWER!!
« Reply #2 on: 17 March 2013, 12:40:47 »
Cheers Doz i'd thought that myself so checked the voltages to the signal wires this morning and im getting voltages at the 2 signal wires which adjust as i move the sensor as they should so im ruling out broken wire to the TPS at this point.
I hate electrical issues, mechanical i can deal with but electrical problems do my head in!!
Any other ideas guys?
TIA
