Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: today..  (Read 8574 times)
Re: today..
« Reply #75 on: 07 August 2013, 20:48:21 »
Even the cat got in on the inspection Cem  ;D Looks a very close match to me and well done for having the patience  :y
[whisper mode on] I'm trying the patience of my wife ;D :y
You will never win  :-* ;D
 ;D ;D
Re: today..
« Reply #76 on: 07 August 2013, 20:48:34 »
Ignore the wife cem - keep it up - liked no. 8, and also like no. 18.
Hope you get the time to paint your Omega, as I know you are spending a lot of time travelling.
Re: today..
« Reply #77 on: 07 August 2013, 20:55:34 »
thanks Dbug..  :y
no 8 and 18 are also my favorites..   :y but once you start doing this you still have the question in mind may be you find a better mix :-\
painting omega now is a far far dream..
Re: today..
« Reply #78 on: 07 August 2013, 21:02:22 »
thanks Dbug..  :y
How is the paint on the omega roof holding out cem  ???
Re: today..
« Reply #79 on: 07 August 2013, 21:27:56 »
thanks Dbug..  :y
the roof laquer has burned out completely and I covered it with many layers of good quality protector polish :(
if I'm going to paint it I will paint completely or I'll burn it
Re: today..
« Reply #80 on: 07 August 2013, 23:45:28 »
thanks Dbug..  :y
 :o :o
I thought you used Epoxy  ??? Must be searing heat , something we are not use to on this Island as its time to put our coats back on  ;D
Re: today..
« Reply #81 on: 07 August 2013, 23:52:05 »
thanks Dbug..  :y
 :o :o
the last months as I planned a complete paint I didnt use protector polish as its sneaky dangerous for paint.. and the sun did its usual job and eroded the last the laquer layer.. and unplanned events did occur unfortunately :(
Re: today..
« Reply #82 on: 07 August 2013, 23:54:32 »
The sun is a right burner out there  :( especially for dark paints  :y
Re: today..
« Reply #83 on: 23 November 2013, 20:09:27 »
finally I got what I searched for.. aşlthough I add some amount of magenta , its not purple on side angles (original color mixture is completely purple when new) and have enough metallic flakes..
as its freshly painted and polished its a bit lighter than the original tone.. when it dries completely it will be 2 shades darker.. but this will take few months..
Re: today..
« Reply #84 on: 23 November 2013, 20:10:41 »
Re: today..
« Reply #85 on: 24 November 2013, 17:06:26 »
although I dont think anyone on here will go in the trouble of testing/trying those colors I share here
for anyone who wants to paint his car with those custom colors in the future..
lines with red are successful imo..
paint is applied as follows :
primary coat : green epoxy (glassurit)  ( spray gun nozzle size : 0. 8)
dry..
sanding : 400 grid wet
1st base coat  (spray gun nozzle size : 0. 8) (mix of directional white + pearlescent+ blue pearlescent) 4 layers   standox
2nd base coat (applied while 1st wet) (spray gun nozzle size 1.0)  for ex 25    applied as 6 layers  1-3-6 longitudinal 2-4 diagonal direction standox
(wait 5-10 minutes between every 2 layer)
dry..
sanding 1200 grid wet
3 rd base coat 6 layers standox (spray gun nozzle size 1.0)
clean with tack rag after dry
clear coat 1st application 8 layers  (spray gun nozzle size 0. 8)  (wait 5-10 minutes) between every 2 layer) standox platinum
sanding 600-800 wet until no orange peel left
clear coat 2nd application 8-12 layers (spray gun nozzle size 0. 8)  (wait 5-10 minutes) between every 2 layer)  standox platinum
sand with 1500 wet until no orange peel and dust left
than 3000-6000 trizact wet..
now the ratios
Re: today..
« Reply #86 on: 24 November 2013, 17:25:13 »
in the above post,  change the emoticon with 0.8 and paranthesis.. as the site dont let me correct them in time..  >:( >:(
Pages: 1 2 3 4 5 [6]   Go Up
