Looking after a car on SORN/semi-retired car
Started by Webby the Bear, 27 March 2013, 17:54:15
Webby the Bear
RIP Paul Lovejoy
Varche
Drive it over here Webby. Have a few days R and R in the sun. I'll look after it till you are good and ready. Meet you at the airport when you are ready!
Hasta Luego Oso   ;D ;D
Webby the Bear
RIP Paul Lovejoy
rikki_essex
Heres an idea have you not got any close friends or family that would use it as there main car and they tax and insure it on the understanding that you want it back every now and them.
regards Rik
Never start a car when laid up unless you're going to drive it. It does more harm than good. Give it some fresh oil before laying up, put the battery on a conditioner, handbrake OFF and just leave it. :y
Quote from: Kevin Wood on 27 March 2013, 23:26:49
Seconded :y
Add to that... If you're planning to park up for longer than 6 months then a teaspoon of oil into each cylinder through the plug hole when it's cold and left and before re-starting it, remove fuel pump relays and crank it over for about 30 seconds (in 4-6 shorter bursts) before starting it :y
Webby the Bear
Quote from: Lazydocker on 28 March 2013, 04:24:04
Seconded :y
RIP Paul Lovejoy
Webby the Bear
Thanks guys. out of interest whats the reason for it being no good to start it every once in a while?
so basically battery out and on charge, new oil, spot of oil in cylinders, handbrake off, leave it  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 28 March 2013, 13:04:47
You will fill the crankcase and exhaust with corrosive products of combustion, yet the engine won't run long or hot enough to boil them off, so they will build up, causing corrosion, while the car is laid up.
But.. put it another way: Why would you start it periodically? ;)
I can't understand the reasoning that suggests it's a good idea (and it's not just you. practically everyone laying up a car seems to add the proviso that "it'll be OK, I'll start it up every week..."). Maybe they think it'll make it easier to start when they put it back into use? In practice, the opposite is probably true.
The engine won't forget how to run, and as long as a few precautions are taken when starting a completely dry engine (e.g. crank it on the starter with a little oil in the bores, and allow the oil pressure to build) it will do much less harm than occasional running.
tigers_gonads
If you have 4 axel stands, it might be a good idea to take some of the weight of the suspension if its not going to be moved for a while.
Not jack up until its off the floor.
Just a few inches to reduce the standing pressure on any joints  :)
Quote from: tigers_gonads on 28 March 2013, 13:30:41
This will help the tyres more then the suspension, IMHO, but still a good idea. :y
Also, reduce tyre pressure and, if possible, cover the tyres if outside, to stop UV light from degrading them.
A desiccant dehumidifier in the interior will do no harm and prevent the damp building up there.
You can go as far as you like... ;)
If you're going to cover the car, however, bear in mind that the cover can chafe on the paintwork in windy conditions and damage it. Some covers also get very damp in the wet and will hold the damp against the bodywork, actually promoting mould and rust. There will also be less breathing into the interior, and no sun to warm it up.
On balance, I'd probably not cover the car, but wash it occasionally - or put it in a garage. ;)
Ill swop you a nice little pug silver bullet for it  :P ;D
Webby the Bear
thanks for the info guys. sorry one more quick question about what you said kev..... what exactly is ''cranking on the starter''?  :-\ is this taking the fuel injector and pump relays out so it cant start but will turn over to get the oil pumped round?
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 28 March 2013, 17:35:06
Yep  :y
other rides
r1
i would also remove the wheels or find a old set to put it on
the reason being that with the car stood in the same place you can get flat spots on the tyres,of course jacking it up will stop this until the local toe rag wants some tyres for his car and comes along one night with his wheel brace and says thank you :y because he hasnt had to jack the car up to help himself!!
