Author Topic: heater matrix blocked  (Read 1471 times)
andy_driver
  • coatbridge
  • my omega had 7 of them + my 74 mini clubman estate
    • my omega of course
    • http://i746.photobucket.com/albums/xx101/andymoto29/omegapic1.jpg
« on: 28 March 2013, 21:53:46 »
i manage to get proper heat into my omega thank god .i used soda crystals out of the local corner shop 1kg bag for a quid result  ;D i used half a cup of soda crystals and 500ml of boiling hot water then get a hose and put it on the bottom matrix pipe just put it all in let it sit for 30mins i done this 3 times and wow the amount of bronw water a small chunks f gunk that came out was amazing hope this helps .
koni adjustable shocks eibach 30mm progrssive rate springs goodridge braided brakeline kit ebc redstuff ceramic brake pads all round black diamond drilled dics at front k+n panel filter  steinmetz body kit
viper357
  • Worthing
    • 2001 3.2 Elite
Re: heater matrix blocked
« Reply #1 on: 29 March 2013, 07:35:20 »
Did you do this with the Matrix still in the car?
Dean
« Reply #2 on: 29 March 2013, 16:09:13 »
Dean, are you having heater problems in the car then?
The reason I ask, is because if your enging is not getting up to temp, it could be having a pretty significant effect on your fuel economy issue...
andy_driver
  • coatbridge
« Reply #3 on: 29 March 2013, 16:58:37 »
  yes i done this with matrix in the car but i removed the wipers and the plastic wiper scuttle its easier to get at the matrix pipes
