Author Topic: mv6 holdback  (Read 2028 times)
sideways steve...
  • gravesend, KENT
  • hi there .
    • 3l mv6 manual estate 1998
mv6 holdback
« on: 29 March 2013, 09:23:27 »
hi peeps .
think i may have a small prob with my mv6.
it seams to hold back for a second or too at about 3000 revs then kicks and takes of like it should .
does it in all gears ..
any ideas.? please
Re: mv6 holdback
« Reply #1 on: 29 March 2013, 09:59:42 »
Sounds like a missfire to me. How old are the plugs?
amba
  • Medway towns
    • German V6
Re: mv6 holdback
« Reply #2 on: 29 March 2013, 10:06:31 »
Got the same symptoms here and have had for the past month or so.
Certain is an ignition fault so either plugs/leads /disspack probably in that order....mine did have a slight leak from the cam cover gasket so imagine it is a lead boot thats starting to fall apart and at high load causing an arc...will investigate when it gets a bit warmer  ;D
Imagine given the year of your car similar ignition fault
Re: mv6 holdback
« Reply #3 on: 29 March 2013, 16:05:22 »
Any vaccum leaks? Any codes stored?
Equally sounds like a flat spot - sure your timing (valve/cambelt timing) is ok?
Also is this a new fault, or has it always been there? If new, when did you first notice it?
2woody
  • Northumberland
Re: mv6 holdback
« Reply #4 on: 29 March 2013, 18:59:36 »
sounds like a vacuum supply problem to the multiram system to me.
Re: mv6 holdback
« Reply #5 on: 29 March 2013, 19:02:15 »
If he'd said 4k I'd of mentioned that too as a possible. ....?
sideways steve...
  • gravesend, KENT
  • hi there .
Re: mv6 holdback
« Reply #6 on: 30 March 2013, 15:46:10 »
only noticed prob in last couple weeks .
dont feel like a missfire to me .
feels like an old carb flat spot.
