Author Topic: Is it possibl to read climate control codes w/oTech2? Where Right side actuator?  (Read 1059 times)
car5car
  • Florida USA
    • 01 Cadillac Catera
01 CADILLAC CATERA 3.0 engine (Omega)
Not sure about the codes, but that actuator will be in the right hand front footwell. Remove the trim from beneath the glovebox, and you should just about see it above/behind the end of the centre console. Arm up is cold, arm down is hot.
The rod connecting the motor(actuator) to the valve in the matrix can pop off, symptom being that the temp on one side won't adjust. :y
