Author Topic: Idling problem  (Read 1807 times)
martin341
  • Finland
  • I do my own stunts.
    • '00 3,0 MV6, '00 2,5 V6
Idling problem
« on: 30 March 2013, 15:01:42 »
Hi,
X30XE engine erratic idling and it failed the gas fumes test on idle. Starts up "fine" when cold and idling ok until warms up. Spark plugs replaced.
No reading on Tech2. So can it be the known ECT( coolant temp sensor) connection failure, all the symptoms match... :(
Any ideas?
Cheers,
Martin
Re: Idling problem
« Reply #1 on: 30 March 2013, 15:03:04 »
What engine exactly?
At a guess 3.0?
Have you cleaned the Idle Control Valve?
martin341
  • Finland
Re: Idling problem
« Reply #2 on: 30 March 2013, 15:20:03 »
Yes, its 3.0
And now, havenīt cleaned the ICV. Any good cleaner advice?
Martin
Re: Idling problem
« Reply #3 on: 30 March 2013, 15:27:59 »
Carb cleaner should do the job  :y
Worth making sure the valve is working correctly, with a screwdriver be careful though!   :)
Re: Idling problem
« Reply #4 on: 30 March 2013, 15:58:21 »
Very very careful with screwdriver - easy to sratch and wreck ???
Once clean very lightly oil with a couple of drops of thin oil (3 in 1 OK) :y
Re: Idling problem
« Reply #5 on: 30 March 2013, 16:00:40 »
I used to put a bit of kitchen paper on end of screw driver and just gently make sure it lifts and shuts ok.
martin341
  • Finland
Re: Idling problem
« Reply #6 on: 30 March 2013, 16:28:31 »
So i cleaned it, didnīt use a screwdriver but cotton buds and cloth. It closes up fine. But the problem stays. After the engine was warm I unplugged ICV and revs went up a little and after re-connecting the engine stalled. Normal?
Cheers,
Martin
