Author Topic: Which iol is best for ageing 3.0 Elite?  (Read 2575 times)
elddis
  • Cannock
    • Omega 3.0 Elite 2001
« on: 30 March 2013, 16:21:58 »
Hi!   Oil change now due   Which oil would you recommend?   Has done 142k   Thanks.
elddis
  • Cannock
Re: Which oil bet for ageing 3.0?
« Reply #1 on: 30 March 2013, 16:23:51 »
Yes,I meant oil!   Car has done 142k   3.0 Elite 2001   Thanks.
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: Which iol is best for ageing 3.0 Elite?
« Reply #2 on: 30 March 2013, 16:35:51 »
I started the first 'best oil' thread in five years the other day have a look here http://www.omegaowners.com/forum/index.php?topic=113301.msg1428582#msg1428582
In my opinion for your car and mileage the best oil would be the fully synthetic 10W60 Mobil 1 'extended life'  http://www.mobil1.co.uk/synthetic-engine-oils/extended-life-10w-60.aspx
Best as in best you could put in, not best value.  Much cheaper semi syns  like the GM/Fuchs 10W40 might be perfectly fine.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #3 on: 30 March 2013, 16:45:00 »
I'd just use the Vauxhall semi syn and change it every 5k. My old Carlton Gsi has about 120k miles on it. If I run that on expensive fully synthetic it just drinks it yet I can use it on semi synthetic and rag it all day on a track day and it doesn't use any. Even my Lotus Carlton runs on semi synthetic but that does get changed every 3k miles.
dbdb
  • west london
« Reply #4 on: 30 March 2013, 16:59:57 »
What spec was the fully syn though, I'd expect that to affect the oil consumption much more than syn v semi syn.  Fully syn is often thinner than semi.  However the Mobil 1 fully syn extended life is a 10W60,  60 so less oil would be burnt at normal running temp.  If you put  0W30 fully syn in I would expect it to get used up quickly.
« Reply #5 on: 30 March 2013, 17:03:36 »
OOF recommendation is for GM 10W40 semi synth :y
Most on here use this
doz
  • Southampton
« Reply #6 on: 30 March 2013, 17:11:36 »
20/50.
« Reply #7 on: 30 March 2013, 17:46:01 »
The general recommendation is to use GM Semi 10W40, and change once it starts to go dark, so probably 3-5k.
Its less than £50 for 4 x 5l cans from dealer if you have Tradeclub.
« Reply #8 on: 30 March 2013, 18:03:07 »
Best as in best you could put in, not best value.  Much cheaper semi syns  like the GM/Fuchs 10W40 might be IS perfectly fine.
Fixed. Fuchs/silkolene. Oe oil. Anything else is aftermarket. ..."Pattern" so to speak. ;D ;)
Edit to add, and as said. On trade club, its a high quality oil at cheapo oil prices. ;)
scottambrose
« Reply #9 on: 30 March 2013, 20:29:04 »
I use millers its great stuff and i supply it at work to the local vx and fiat dealers :y
doz
  • Southampton
« Reply #10 on: 30 March 2013, 20:40:37 »
+1.
20/50 semi synthetic is hard to come by but they do a good classic competition oil in that grade.
« Reply #11 on: 30 March 2013, 20:44:29 »
+1.
Yep Millers are great for the old "classic" oils :y
